Guestimate my HP?
High all. I know this has been asked a thousand times,but what do you think I'm putting down? I'm running mods in my sig, &TNT SW-9/TM-2/TQ-2/RP-2/WG-off. I'm able to hold RP good enough to not smoke much at all @ WOT. It feels slightly stronger than 4.4 did on Sw-9. With 4.11 I put down 430/800 on a dynojet but the truck realy didn't like that tune. It realy likes this one. Thanks.
I'd say you're knocking on 500's door right now....and then some. Your CP3 and stix are gonna limit your potential as it is with me right now.
X2! Like said, limited a tad!
490/940ish is my guess.
i just dynoed w/ tnt & HTT & stock fuel system and put down 520hp. You should be in the same neighborhood
So a turbo and smarty is basically 500hp? Those are near future mods so it sounds good to me.
You can actually get 500 out of the stocker, but things will be toasty.
Does anyone think that his 65 wheel might be holding him back at around 480ish??? I am thinking that Drive Pressure might be a little high and holding back power more than his stock stix are???
If it helps. I did put down 468hp with 4.11, & Quad XZT pressure only. That was the day I had the turbo installed, & it had about 5 miles on it after the install. It spools a lot better now. With TNT now, I'm seeng 38-40# boost almost as fast as the stocker got there. I went with the 65 wheel for towing in the mountains. It is the 13cm housing, & it's supposed to flow as much as the 14cm according to the guy I talked to @ HTT. Also, I'm very happy with the performance, but just don't have a dyno around here that I can run it on.
I have to correct myself. My truck put out 476/868 on 4.11+XZT on the day I had the turbo installed. My SOTP power meter says I'm making more than that now, & waaaay smoother too, with very little smoke.
I wish there was a dyno closer to me, so I could run it again.:( |
You could always go buy an IPhone and download the new Dynolicious program, and that will give you a pretty accurate idea of HP. Or if you know someone with an IPhone and convince them to get the APP then you can tell!!
Originally Posted by smoke19D
(Post 2185450)
Originally Posted by rip 112
(Post 2185516)
Im still on my stocker turbo and over 500. I do hope to upgrade the turbo soon though. .. |
Originally Posted by ShakinRedCTD
(Post 2187854)
What settings??? I just did 484 / 1006 with Revo TNT. Looking to try...Tried numbers.
I just dynoed over the weekend at Scheids with the Smarty TNT with stock cp3, injectors and turbo and made 470hp 963tq. I do have cai exhaust and a Fass 150.
