Guestimate my HP?
Guestimate my HP?
High all. I know this has been asked a thousand times,but what do you think I'm putting down? I'm running mods in my sig, &TNT SW-9/TM-2/TQ-2/RP-2/WG-off. I'm able to hold RP good enough to not smoke much at all @ WOT. It feels slightly stronger than 4.4 did on Sw-9. With 4.11 I put down 430/800 on a dynojet but the truck realy didn't like that tune. It realy likes this one. Thanks.
Does anyone think that his 65 wheel might be holding him back at around 480ish??? I am thinking that Drive Pressure might be a little high and holding back power more than his stock stix are???
If it helps. I did put down 468hp with 4.11, & Quad XZT pressure only. That was the day I had the turbo installed, & it had about 5 miles on it after the install. It spools a lot better now. With TNT now, I'm seeng 38-40# boost almost as fast as the stocker got there. I went with the 65 wheel for towing in the mountains. It is the 13cm housing, & it's supposed to flow as much as the 14cm according to the guy I talked to @ HTT. Also, I'm very happy with the performance, but just don't have a dyno around here that I can run it on.
I have to correct myself. My truck put out 476/868 on 4.11+XZT on the day I had the turbo installed. My SOTP power meter says I'm making more than that now, & waaaay smoother too, with very little smoke.
I wish there was a dyno closer to me, so I could run it again.
You could always go buy an IPhone and download the new Dynolicious program, and that will give you a pretty accurate idea of HP. Or if you know someone with an IPhone and convince them to get the APP then you can tell!!
I ran sw9 tim2 rp4 tq3 wastegate off. I didn't mess with the shift defuel because i have a 6-speed. next time i'd like to try tq4 and see if i can get more. i'm also looking to put my fass on soon and i hope that gives me a little too.
