got some codes
Old Mar 28, 2006 | 08:36 AM
Agades's Avatar
got some codes
0606
0647
2149
anyone know
I think the 606 is just a companion code
and the 2149 is an injector code pointing to my injector harness for the tst
but the 647 is a new one
Old Mar 28, 2006 | 12:49 PM
Foxborough's Avatar
codes
p0606 = Internal ECM Processor
p0647 = A/C Clutch Relay circuit high
p2149 = Fuel injector Group 2 supply voltage circuit
I got this from a thread in here. at the top "listing; Common FAQ- IE, ODBII, ODBIII; computer fault codes." I could not find it. I could scan it and send it somehow in you need.
Old Mar 28, 2006 | 01:38 PM
Foxborough's Avatar
found code list
FAQ
DieselTruckResource.Com FAQ Listing : Common FAQ - IE, ODBII, ODBIII etc. : Computer Fault Codes
Question: What are the fault codes for my ODBII equipped vehicle?
Answer:
P0016 Crankshaft/Camshaft Timing Misalignment/Out-of-Sync
P0071 Ambient Temperature Sensor Performance / Rationality
P0072 Ambient Temperature Sensor Low
P0073 Ambient Temperature Sensor High
P0088 Fuel Rail Pressure Too High
P0106 Manifold Absolute Pressure Sensor Performance / Rationality
P0107 Manifold Absolute Pressure Sensor Low
P0108 Manifold Absolute Pressure Sensor High
P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
P0112 Intake Air / Charge Temperature Sensor Low
P0113 Intake Air / Charge Temperature Sensor High
P0116 Engine Coolant Temperature Sensor Performance / Rationality
P0117 Engine Coolant Temperature Sensor Low
P0118 Engine Coolant Temperature Sensor High
P0128 Cooling System Error / Thermostat Rationality
P0148 Fuel Delivery Error
P0169 Water-in-Fuel Detected For Too Long
P0192 Fuel Rail Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0201 Fuel Injector 1 Circuit
P0202 Fuel Injector 2 Circuit
P0203 Fuel Injector 3 Circuit
P0204 Fuel Injector 4 Circuit
P0205 Fuel Injector 5 Circuit
P0206 Fuel Injector 6 Circuit
P0217 Coolant Temperature Too High
P0219 Engine Overspeed
P0234 Turbocharger Overboost Condition
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
P0237 Turbocharger Boost Pressure Sensor Low
P0238 Turbocharger Boost Pressure Sensor High
P0251 Injection Pump Fuel Valve Feedback
P0300 Multiple Cylinder Misfire
P0301 Cylinder 1 Misfire
P0302 Cylinder 2 Misfire
P0303 Cylinder 3 Misfire
P0304 Cylinder 4 Misfire
P0305 Cylinder 5 Misfire
P0306 Cylinder 6 Misfire
P0335 Crankshaft Position Sensor Circuit
P0336 Crankshaft Position Sensor Performance
P0337 Crankshaft Position Sensor Circuit Low
P0338 Crankshaft Position Sensor Circuit High
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Performance / Rationality
P0381 Wait-to-Start Lamp Inoperative
P0461 Fuel Level Sensor 1 Performance / Rationality
P0462 Fuel Level Sensor 1 Low
P0463 Fuel Level Sensor 1 High
P0477 Exhaust Pressure Control Relay Low
P0478 Exhaust Pressure Control Relay High
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
P0483 Cooling Fan Speed
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
P0514 Battery Temperature Sensor Performance / Rationality
P0516 Battery Temperature Sensor Low
P0517 Battery Temperature Sensor High
P0521 Oil Pressure Sensor Performance / Rationality
P0524 Oil Pressure Too Low
P0532 A/C Pressure Sensor Low
P0533 A/C Pressure Sensor High
P0541 Intake Air Heater Relay 1 Low
P0542 Intake Air Heater Relay 1 High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 High
P0580 Speed Control Multiplexed Switch 1 Low
P0581 Speed Control Multiplexed Switch 1 High
P0602 Control Module Programming Error/NotProgrammed
P0604 Internal Control Module RAM Integrity Failure
P0606 Internal ECM Processor
P0607 ECU Internal Performance
P0622 Generator Field Control Circuit
P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low
P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High
P0630 VIN Not Programmed in PCM
P0633 SKIM Key Not Programmed in PCM
P0642 Sensor Reference Voltage 1 Circuit Low
P0643 Sensor Reference Voltage 1 Circuit High
P0646 A/C Clutch Relay Circuit Low
P0647 A/C Clutch Relay Circuit High
P0652 Sensor Reference Voltage 2 Circuit Low
P0653 Sensor Reference Voltage 2 Circuit High
P0698 Sensor Reference Voltage 3 Circuit Low
P0699 Sensor Reference Voltage 3 Circuit High
P0700 Transmission Control System (MIL Request)
P0837 Four Wheel Drive (4WD) Switch Performance / Rationality
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P1652 J1850 Communication Bus
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Validation Switch 2 Low
P2128 Pedal Validation Switch 2 High
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2266 Water in Fuel Sensor Circuit Low
P2269 Water in Fuel Condition
P2502 Charging System Output Voltage
P2503 Charging System Output Low
P2504 Charging System Output High
P2509 ECM/PCM Power Input Signal Intermittent
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 High
P2609 Intake Air Heater System Performance
Old Mar 28, 2006 | 02:06 PM
Agades's Avatar
cool
thanks
Old Mar 28, 2006 | 04:10 PM
ATVConnection's Avatar
Anyone know what codes P0050 and C0101 mean?
Old Apr 1, 2006 | 03:20 PM
WSA308's Avatar
Also wondering what some of these things might affect.
I'm getting P0633 and P0602. They are PCM and ECM programming errors. How will these affect my truck. I am currently experiencing a rough idle and possible injector miss. Could either of these be the cause? No intent to hijack but if someone knows where I cand find the info I would be greatly apreciative.
Old Apr 1, 2006 | 08:25 PM
Tom488's Avatar
P0606 - TST detected (okay, actually an ECM Hardware error - but it's just something the TST trips from time to time. Supposedly TST's later versions don't trip this code. I'm running the later Twins program, and I've never seen it. I have seen it on my early single programmed unit)
P0647 - High voltage detected at A/C clutch relay. Relocate your TST ground from the battery to the dash frame inside the cab. This is discussed in the FAQ section of TST's website. I know it sounds bizarre, but it works. I had A/C compressor problems (would turn off intermittently), and solved them by relocating this ground.
P2149 - As you said, this is a problem with the injector harness - the ECM thinks something's shorted out.
P0050 - This means your ECM is suffering from multiple personality disorder... it thinks it's controlling a gas engine. P0050 is an oxygen-sensor-related code.
C0101 - This sounds like an instrument cluster code. If you got this by holding the odometer button down while cycling the ignition key, it refers to an airbag warning indicator output circuit shorted, and it occurred 1 key cycle ago (the first '01' is the code, the second '01' is number of key cycles since last detected)
As to the P0602 and P0633 errors, P0633 means the security code for the Sentry Key system isn't programmed (ignore this if you don't have a Sentry Key - thick gray plastic handle on the ignition key). P0602 is an ECM checksum error - meaning it wasn't flashed properly. Have you been using a programmer? If so, revert back to stock, and try programming again.
Old Apr 1, 2006 | 11:12 PM
WSA308's Avatar
Tom488-thanks for the info. I do have the Sentry Key so is this something I need to take in to the dealer to deal with? Never seen either of these codes before I left a bunch of electronics on for a week and my battery went dead. Could this have caused these issues? Also where do you get all the data on what may have caused the code.
Old Apr 4, 2006 | 08:49 PM
WSA308's Avatar
Just got back from a local Cummins Mechanic (Non-dealer) plugged in the laptop did a full system scan (same as what was apparently done a week ago at the dealer) and got a P0122 code which is apparently Boost sensor failure. May be causing the error in the ECM, explains the loss in performance and poor fuel economy. I wil try the reload though and see if it changes anything.
I was there for three hours today and the guy never charfed me a cent, didn't try to sell me nothing and said go to dodge and get one on warranty. Not many people would do that anymore. I said when I do some upgrades I will be back!
Old Apr 4, 2006 | 09:58 PM
WSA308's Avatar
If you want to run the cummins diagnostics code reader and have a laptop with a OBD cable this program from cummins may help. I have not tried it yet as I just found it this evening. I will post my findings.
http://insite.cummins.com/icon_en.html
Old Apr 5, 2006 | 10:15 AM
CTDHokie's Avatar
I did not think Cummins could talk to our ECU's didn't DC lock them out?
Old Apr 5, 2006 | 04:20 PM
WSA308's Avatar
Cummins provides DC with the hookup for the ECM from what I understand so far. If you want to spend the cash you can get ti INSITE program for a yearly subscription fee and the Inline 4 or 5 modules are between $250 and $300 from cummins. I am still researching. I figure if the pimple face kids in the service department ca read a computer so can I.
Old Apr 19, 2006 | 06:21 PM
WSA308's Avatar
Further to this point, the heavy duitymechanic that I took my truck to (Non-dealer) could read my codes with the program and links that he purchased from Cummins. He says that he can get more detailed information as to what is causing the codes that our code readers ar picking up. This is how he diagnosed the boost sensor problem.
I'm sure that some of the truck racers and sled pullers have a method of getting into the system without going to dodge.
Old Feb 7, 2014 | 09:37 AM
Ryan G Ray's Avatar
Question Codes popping up on work truck
My work truck has been not wanting to start since Tuesday Evening and it has shown the following codes. I googled what they mean but it still doesn't explain why they would be showing up when trying to start the truck.
P0217 - Coolant Temp Too High
P0480 - Cooling Fan 1 Control Circuit / Open ( Low Speed Fan Relay )
P0483 - Cooling Fan Speed
P0521 - Oil Pressure Sensor Performance / Rationality
Can someone explain what these codes mean. Truck will not start at all, have tried daily to get it started
Old Mar 27, 2014 | 01:57 PM
bullrambler's Avatar
Thanks for the list it has been very helpful.
