going to track how much hp...
Old May 3, 2009 | 11:11 AM
moparman13045's Avatar
I have an 04.5 with stock injectors, aurora 3000 turbo, ats 2 piece manifold, ats transmission with deep pan and co-pilot, mbrp catback duals, fuel boss lift pump and 2 micron filter. I have quadzilla commander with fuel pressure for monitoring all the goods. The ATS transmission has the five star converter also, but they told me it doesn't have any billet shafts.
I have a smarty revo software s06 I don't want to hurt anything and I want to go to track next weekend for test and tune and have fun. What setting or hp level would i be safe adding to this truck?
I am also wondering what power level I could do once I get billet input shaft in trans, which I am going to order this week. thanks
Old May 3, 2009 | 11:48 AM
mikmaze's Avatar
that is a loaded question, no way to safely say, a lot depends on how much boost you try to hold at the line. stock output shaft can give right there on the line without any warning.
Old May 3, 2009 | 06:03 PM
yes
I understand that, guess I am looking for a rough idea of what you guys would do, how would you guys launch it exactly.
I am not planning on doing a boosted launch. Just launching with a few r's maybe 4 psi at most. I don't need to go ballistic just playing around at a test and tune.
Old May 3, 2009 | 06:31 PM
mikmaze's Avatar
2 wheel drive launches should be safe, I know I was fine with about 15 starts in 2wheel before I finally turned it up enough to make 2 wd a smoking laugh, and joined the billet output club 4x4 launches from now on
Old May 3, 2009 | 08:45 PM
jgiachino's Avatar
w/o shafts, i'd keep the psi at launch pretty low..i do 10psi 4x4 with just a billet input and it held fine for the 6 runs i've done...powerwise, you have enough to turn revo up to 7 or 9.....just watch the launch to protect the trans.
CTD2001
Aug 22, 2009 10:03 PM
Billm2004
Mar 1, 2008 04:22 PM
BigJohnston
Jan 29, 2008 09:18 PM
imelmo
21
Mar 28, 2006 12:27 AM
