Glowshift Guages???
Old Oct 24, 2007 | 03:36 PM
redeyedracer's Avatar
Glowshift Guages???
Is anyone out there running these???? They can be purchased from the manufacturer (i think) on ebay for VERY cheap, just wondering if if anyone has some experience with them??
Old Oct 24, 2007 | 03:53 PM
Rpainter's Avatar
I am running the fuel pressure gauge 0-100 psi on truck about 1 year no problems yet.
Old Oct 25, 2007 | 03:36 PM
anyone else???
Old Oct 25, 2007 | 07:40 PM
Blast Chamber's Avatar
I just ordered three GS gauges today for my '98 (Fuel Pressure, Oil Pressure, and Tranny Temp). I'll report back in a couple of weeks after I get them installed.
FYI, I ordered directly from their website using coupon code GSPC and got 15% off. Total for the 3 gauges plus a pod and shipping came to $146.
Old Oct 25, 2007 | 09:48 PM
zchornyak's Avatar
I just installed mine today. They were cheap on ebay. 170 bucks. Three gauge a pillar w/speaker hole, egt, boost, and tranny temp. The egt is the only one I have hooked up so far. No complaints with that. The boost only reads up to 40 psi. They do come however pretty complete, (with the thermocouple). Not a bad deal and you can change the backlight colors.
Old Oct 26, 2007 | 11:41 PM
airboy's Avatar
Pix Pix Pix!!!
Old Oct 27, 2007 | 04:08 PM
zchornyak's Avatar
Old Oct 27, 2007 | 06:04 PM
Looks great, zchornyak! Were you able to wire the Glowshift gauges into the headlight dimmer switch so they would dim with the dash lights?
Old Oct 28, 2007 | 10:59 AM
zchornyak's Avatar
I currently have them wired to the ignition. There is a way to wire them so that they will remember the color you have them set to. And I think you could easily modify that to incorporate the dimmer. The directions say to have one wire go to the ignition and one to the battery. (for the color memory) If you wire the ignition to the dimmer I think it would dim with the lights.
Old Nov 20, 2007 | 11:52 AM
I ordered a set for my 06...after talking with a tech on the phone he told me that none of the 7color gauges are capable of dimming, also if you do hook it up to the dimmer switch it will damage the gauge...im using the dash pod and plan on putting in a seperate switch for the gauge lights...i got boost 0-60, egt 0-2400, and fp 0-100, and the dash pod for 185 shipped using the discount code (gspc) Blastchamber provided, saved me like 30 bucks....thanks!!!!
Old Nov 20, 2007 | 02:26 PM
I'm glad the code worked for you, redeye. It's always nice to save some $$.
You're correct about these gauge lights not being dimable. The gauge mechanicals and lighting receive power off the same wire, so I'm not sure how you will be able to control the lighting with a switch.
I haven't had time to install my gauges yet, but did hook them up to a 12-volt power supply to see how bright they are. I think they will be OK without a dimmer as they didn't appear obnoxiously bright. I'm hoping to have them hooked up by the end of the month.
Old Nov 20, 2007 | 02:57 PM
zchornyak's Avatar
I wish I had that code when I bought mine!!! I still got a decent deal though. The brightness isn't too bad. You can change the color to red so as to not affect your night vision....oooo James Bondish! If you wire them right they should remember the last color you left em on too.
Big Red 97'
Nov 6, 2008 10:38 AM
Oscar1017
Oct 14, 2008 01:28 PM
sodbuster03
Oct 12, 2008 08:59 PM
deking1970
Mar 15, 2008 02:14 PM
dtycoon2003
Nov 6, 2006 09:29 PM
