GFS392 elec.
Old Aug 28, 2007 | 05:59 PM
sentzible's Avatar
GFS392 elec.
Need help on wiring 2 way switch to switch between walbro & stock pump. I have the performance kit which is capable of switching plugs under truck, but don't know if running wires to dash will loose to many amps as stock pump appears to have no relay.Any addvice & pic's would help.Thanks ED
p.s. It may take time for me to reply
as I don't type. Letters on keypad
arn't in order.
Old Aug 28, 2007 | 08:03 PM
MikeyB's Avatar
Question: Why do you want to keep the stock lift pump inline with the GDP pump?
The GDP kit comes with a wiring harness with a relay. The connector plugs into the harness for the stock lift pump. Just need to wire the relay for 12v and ground.
MikeyB
Old Aug 28, 2007 | 08:19 PM
sentzible's Avatar
Stock pump is still good. Just like to have backup without going under truck to change plugs.Pump is in tank. Thanks for reply. ED
Old Aug 28, 2007 | 09:00 PM
shortbed rv's Avatar
Will the GDP draw through the stock pump when the stock pump is not running? Or do you have a seperate pickup for the GDP?
Old Aug 29, 2007 | 02:08 PM
sentzible's Avatar
Seperate pickup tube from GDP
Old Sep 3, 2007 | 06:23 PM
sentzible's Avatar
Anyone with advice or links to posts to help as I'm trying to do this, this weekend. Thanks, Ed
Old Sep 3, 2007 | 08:57 PM
CRXsi's Avatar
I wouldn't run the pump wires to a switch inside...instead I would install a relay with a 15A min fuse to supply power to the Walbro and run the low current wires for the relay into the cab on a switch. You could use any relay rated at 20A or higher from you auto parts store, an accessory fog light relay from Bosch would do the trick nicely.
Sixpack73
Jun 19, 2007 02:13 PM
jrturbot
Nov 23, 2003 01:46 PM
hotdram
30
Jun 26, 2003 04:35 PM
SolidJunkMM
Jun 21, 2003 08:09 AM
Demon_Customs
13
Dec 19, 2002 07:14 PM
