Gauges on my 2004 Ram 2500-Newbie
Okay, here is what I experienced this weekend when towing approximately 10,000lbs.
My pyro/egt dial shows a range from 0-16 (not like the other ones in 1000 intervals). When towing uphills with the overdrive off (light on) the gauge showed 6-7, with the overdrive the gauge showed approx. 8.5. The gauge start creeping up to 8- 8.5 when I was going uphill only, in normal highway stayed at 6-7. Now my boost gauge, uphill with overdrive off when up to 30 or so, but stayed up there for a few seconds and then it went down. The boost gauge shown on a flat range was from 5-15. The trans temperature stayed pretty cool until the stop and go routine, normally 160 at driving, stops go 180 and backing up with the trailer to a max of 210. I also noticed that when I used the overdrive off, my pyro/egt gauge stayed cooler even on hills (6-7). I had to use the overdrive off on hills or else I could not get high rpm's, with overdrive on and uphill 1100 rpms. With overdrive off went from 2000 to 2600 rpms. Should I keep using the overdrive off when going to hills to keep my rpm's high, or it does not matter. To keep my rpm's at least 1700 rpms I have to be cruising approximately 55 miles per hour with the trailer attached. Sometimes I could not keep that speed of 55mph and that was the time I had the overdrive off to keep my rpm's higher than 1700. Should I continue to use the overdrive off and on depending the rpm's the truck shows, or do not worry about the low rpm's because I can get up over 50 mph's and then my rpm's will go over the 1700.
wengerda, it sounds like you were getting it right. With that big of a load you will have to drop it out of O/D on the higher grades. I beleive you have the 2004.5 since your truck was built on 3/04 which means peak torque is 1,600 RPM so if you fall below 1600-1700 I would downshift or if you find that the tranny is shifting between 3rd and 4th(O/D) then drop it out of O/D as well. No problem with keeping the RPM's at 2,500 uphill, just keep an eye on your EGT's and you'll be fine.
Karl
Karl
Karl
Karl
my pyro on the gauge face goes from 0-16 [i have the autometer ultra lites] but if you read the small text on the gauge face, it shows x100 on the scale. same deal on your tach. it reads 0-5, but they are in x1000 range... and 1300°f is a good point to start letting off the throttle. i can get to about 1250°f on a hard pull, and i don't have any fueling mods yet...
Donmacky
Feb 1, 2014 06:07 PM
marksblaster
Oct 27, 2012 11:26 AM
skoloski
22
Nov 29, 2007 06:50 PM
coontz0473
17
Sep 22, 2006 03:52 PM
