Gauges on 06, eengine temp port?
I'm installing some gauges on one of my brothers work trucks and there's an engine temp gauge, where or wich port can I use on the engine? Also he has a mech boost gauge, do I cut the wastegate pressure line and T off of that? And in what direction do I run the plastic tubing to keep from excessive heat?
Thanks alot guys
I've only ever installed electric gauges, so I'm not so savvy with these mech ones.
Thanks alot guys
Use a boost bolt for the boost. Do you mean exhaust gas temp? Or coolant temp?
http://dieselmanor.com/diy/CMS3-gaug...ugeinstall.htm
shop: "so its a diesel with a 5.9, huh"?
me: "Yes sir 2006 dodge"
shop: "looks like its in the front SIDE of the engine theres a bolt there, thats where it goes."
me:
QWKRTNU
Sep 26, 2006 10:22 PM
AndyZ
May 11, 2005 06:32 PM
