Fuel Pressure or Rail Pressure Guage
All, i already have the standard 3 diprocol guages (EGT, Boost, Trans Temp)...am getting a gdp kit installed, so i want to get a fuel related guage...just one....so the question is what is most important...fuel pressure or rail pressure....if fuel pressure, do you recommend the 0-30psi or the 0-100 psi version? I'm under the impression that the 0-30psi is sufficient for the gdp 392 on our trucks....thoughts?
Also, where to mount? i have the 3 place a pillar currently....anyone use a bullet single pod? where did you put it? |
For the prices of the guages, a Quadzilla fuel pressure guage would be the trick! You get both fuel and rail pressure in one pod. Mount it on the top of the column and there you have it!
... because you definitely will benefit from having both fuel gauges!
You need both either the Commander or the or the pod that does the both.
Originally Posted by vzdude
(Post 1588979)
I like the looks of the manual guages as well, but I couldn't buy all of the ones I wanted for the price of a Commander. I'm liking it a lot now, just takes a little to get used to.
can't go wrong with the quad gauge. Works great, easy to install, and has nice features that a standard analog gauge doesn't have (low and high pressure recall with alarm)
http://i139.photobucket.com/albums/q...jpspics035.jpg |
Originally Posted by jlibert
(Post 1589894)
http://i139.photobucket.com/albums/q...jpspics035.jpg JG |
I ordered the quad digital RP/FP gauge last night. Says it should be here by Friday. I can't wait. I have ordered a bunch of stuff the past 24 hours.
Yeah, i told my wife i'd take a break after i got the tranny installed last weekend....i lied.....ordered gdp and now quad guage....then i'll stop...for another week....:-)
Originally Posted by jgiachino
(Post 1591004)
jlibert thanks for posting a pic of the quad gauge. I have one coming also.
looks like its a hot setup |
(Post 1589776)
i run a large IT department (lots of computers / electronics)....but for some reason, like the old school guages in my truck.....cant figure it out, everything else i own is brand new, hi tech....
Originally Posted by XLR8R
(Post 1592154)
You probably prefer analog because they're so much easier to read at a glance when the vehicle is in a dynamic environment... same reason we liked gauges w/needles in the aircraft! :cool:
I think you're right...and for the record, my trucks only in a "dynamic" environment when my wife's driving it! :-) |
ive had my quad rg/fp for about 2 weeks or so...and i like it. its hard to find a place thats convient though. i have mine in the same place as jlibert, but sometimes when the sun hits it you cant read it and its to low depending on where you keep your steering wheel. overall a great product, but if i could change on thing it would be that the cable goes into it on the left side. also dont know how accurate the fp is when reading off the fuel filter housing?
brett |
