Fuel pressure placement question
do not use the cap it measures the pressure before the filter not after like it needs to be. go back to geno's and get the taped banjo bolt, # bf-taped, i see that you are going to add a cp3 the easiest place to put the bolt is on the cp3 but this will be in the way of the second one. replace the bolt on the bottom of the filter instead, it is not as hard as it looks you can turn the wheel and access it from the side
I'm going to use this fitting right into the Cp3. Ordered it yesterday for my AirDog 100 kit install.
You can buy it here: http://www.vulcanperformance.com/category-s/190.htm
Roger that thanks guys well its gonna be a while before anything else gets done to the truck i have a bunch of go fast parts here to add but since my back surgery in Feb im still not able to do much ( something is still messed up in my back ) and i refuse to let people here in Hell Paso work on my truck if i was back home that would be fine but never here.. but again thanks for the info guys i just thought that was a neat idea with the cap
OH Carl48 how do you like the DDP injectors did you install them yourself and what about the cam id like to hear some input about them i would like to go with the 90's or 120's but again id like to hear from someone that has DDP injectors and your thoughts about your cam Thanks
wap
Jul 16, 2007 07:01 AM
D.Wiggs
42
Sep 21, 2006 07:18 AM
