fuel pressure guage
Ok, I recently installed a fass titanium and have been looking at installing a fuel pressure guage in the cab. I know I can come off the fass pump, but I have read that when installing a guage on my truck, that you should install a snubber to prevent high pressure spikes.? I am assuming the snubber would be mounted at the cp3 , which leads me to believe that is where I should come of of with the guage line? Anyone have any suggestions or advice? Thanks.
Should only need a snubbed w/ a rail pressure gauge. I got the additional pressure sensor for my CTS, mounted it to the lift pump at the provided port, added 5' to the harness for a clean routing. Works perfectly.
Originally Posted by mykaos
(Post 3281722)
You'll need to get the "expandable cable" kit. That will allow you to add extra sensors. That particular part has to be purchased from EDGE. Then the additional sensors / harness kits can be either purchased from EDGE (as I did, just easier for me) or you can build your own. Once that is built / installed, you will need to program your display through your laptop using the software enclosed w/ your CTS. I'm probably making it sound more complicated than it really is.
(Post 3281741)
