Fuel in Crankcase??
Fuel in Crankcase??
I am not sure were it would be coming from. The crankcase is full of fuel, I mean right up to the handle of the dip stick. First of all I was driving the truck to work this morning truck ran great. came up to a stop light and the check gauges light came on looked at gauges and there was ZERO oil preasure. but came back when started to drive. that's when I discovered oil all over bottom of truck and tail gate. check oil and it was full all the way up to the handle of dip stick?
The truck runs fine starts smooth, I thought it could be the transfer tubes from the rail to the injector.
I talked to some one else and they said it could be the cp3 leaking out the front seal?
I could use some idea's from others.
thank you Justin
thank you Justin
BigBRUNO4
Sep 9, 2006 06:30 PM
rattle_rattle
Jun 21, 2003 12:02 AM
