Fluxed & TNT'd
installed my F2's last night, along with the TNT program.
The Flux injectors came DHL, which in my neck of the woods suck as far as deliveries go. They didn't make the drop off and i had to make a 2.5 hour trip to pick them up[duhhh] The install went smooth, and I can't believe how much smoother of an idle I have with the Flux vs. stock or the DDP 90's I previously had. Cruising temps are in the same range as the DDP's. The TNT program seems to have less midrange power, and a much stronger top end power curve than the 4.3 I was previously running. EGTs are the same, max boost is the same, and rail pressure on the #3 setting is about 7k at idle vs. 10k with the 4.3. Wot I see 23k with both programs. This was on sw9, #2 timing, #3 rail, Moderate TM, WG off, Shift defuel on (not sure if it makes a difference on a manual trans?) I'm loading some different settings to try and get it dialed in. I got an 0234 turbo charger overboost code, and when the rpms drop the hold in the 1500 rpm range for 2-3 seconds, then intermittently drop to 950 rpms and hold indefinitly until i tap the accelerator pedal at which point they drop back to the normal 750 rpms. No other smarty program has done this on my truck. Thanks to Don M and Browns Diesel for getting me the injectors 2 days BEFORE the promised date[guitar] No thanks to DHL for crappy delivery, and thanks again to Bob and Marco for all the work they do long after the customer has purchased their product. |
DHL is the worst carrier of them all!!![yuk] It always takes more time with them than any other carrier. Every time I have ever dealt with them they are late by days.
Glad to hear you got your sticks in must suck waiting for the call. As per your truck holding rpm's at 1500 mine seems to do the same takes couple seconds for it to kick down lower, not much of a problem just not used to it. I may go back to the 4.4 or try my luck on standard revo.
Did you notice a power difference between the DDP's and flux's, Im on the fence on which one to get?
Turn your wastegate setting to "stock" and you can get more boost without throwing a code. What's the most boost you were seeing when it threw the code?
Originally Posted by LakeLife79
(Post 2083263)
Originally Posted by Hintz
(Post 2083262)
Originally Posted by jlibert
(Post 2083280)
I can't make any comparisons on power, because I changed the program at the same time. I did notice that the truck is very quiet now, and idles very smooth. I sold my DDP's to a friend, and he is happy with them. I'm curious as to how the fuel mileage will compare.
I've tried the program with the wastegate on and off, and still get the 0234 overboost code. Any ideas? Didn't ever have a problem throwing that code before at over 50 psi.
Can you get a fooler to try out JP? How hot was it there today?
(Post 2087539)
Originally Posted by Don M
(Post 2087695)
Originally Posted by bluechrome
(Post 2087950)
Do you have a Pressure box that does not do boost fooling? My power puck does the same thing if I don't run a Boost fooler
JP...
White smoke kinda haze??? Wonder if the o-rings were no good....have you checked you oil level yet???? What about coolant level???? Hope it's not bad man...you dont deserve anything bad....you should only have good "KARMA" for all the help you gave me!!!!! |
Originally Posted by 2007 5.9
(Post 2088111)
JP...
