Fitting 35s
Fitting 35s
I have MKWs and i looked up the offset and backspacing, this is what i found 12 and 4.97. Any idea if i can run 35s without rubbing? or what is the biggest tire size i can fit under my leveling kit?
thanks guys
thanks guys
With that MKW Wheels you have. It will rub w/ a 35" tire. It will also stick out atleast an 1 1/2"- 2" past the wheel well than stock.
As for what size tire for your leveling kit. A 35" will work fine, but you need to have the correct backspacing wheel to make it work. You need 5.5"-6" and a 8"-9" wide wheel for a perfect fit w/o rubbing and enough room to go off roading (if you go off road).
It will stick out a little, if you like that style. I personally love the tires stickin out a little it gives it an aggressive look. They will rub the back of your fender though. My wheels are 20'' dc-1s,-13mm and 4.5'' of bs, and they rubbed my fender until i did some fender trimming. It looks great and you can't even tell i cut the fenders. Oh yea i have a 2.5'' leveling kit, hope this helps.
The tire size is not what dictates what you can put under there it is the wheel BS.
A few posts down I am going through the same problem. I want a 35 and the wheel choices that are out there (at least the ones I like) are few and far between.
The wheels I have found are 17x8.5 with 5.375" BS and +15mm offset. I am gonna try and run these with some 35x12.50's or if I get the Toyos it will be 35x13.
Well I really dont understand the offset thing. I do understand the BS. I think with a 35 you are gonna be pushing it with a wheel that is shy of 5" BS.
I am wondering if the wheels I have picked out that are 5.375 are gonna fit. Granted they are 8.5 instead of 9" like yours....that will be the only help.
You need a wheel with a backspacing value as close to 6" as possible AND have a positive offset value. Mine are-- 5 5/8" backspacing and a +14mm offset on a 20" x 9" rim. No rubbing, no trimming, no bs. I do have a level kit though.
If you aren't going to change to the necessary wheel specs then you can't run 35's without rubbing--even with a level kit. You will probably be able to run 33's but you may want to test fit them to make sure.
nauitque21
17
May 12, 2005 08:50 PM
nauitque21
May 2, 2005 09:16 PM
scarecrow
Mar 9, 2005 09:04 PM
CTDHokie
Jul 27, 2004 05:06 PM
