Fisher snow plow which battery
Old Dec 5, 2006 | 09:40 PM
sr148's Avatar
I just installed a 8 ' fisher MM2 snowplow, question is which battery is the correct battery to install my power for the plow, right now I am installed on the passenger side battery and everything works but is this ok or will it get more power from the drivers battery ,, thanks in advance
Old Dec 5, 2006 | 11:03 PM
ptgarcia's Avatar
I don't think it will matter. Wouldn't both be able to supply the same amount of juice? Otherwise you end up with an unbalanced system. Am I missing something?
Old Dec 6, 2006 | 07:24 AM
Patriot2500's Avatar
Not sure if it matters either, but when the plow dealer installed my Western, they hooked everything up to the drivers side battery.
Old Dec 6, 2006 | 08:22 AM
05CTDN8's Avatar
Both batteries are "electronically" equal. As the system draws power it will pull amperage from both batteries at the same time. The only time you will have an issue is if one of your batteries has a dead cell and is weaker than the other. In this case, the weak battery will fall off faster than the healthy one causing a majority of the load to be covered by batt 2. This will at times cause premature battery failure on batt 2 due to the over stressing of charge/discharge cycles.
Old Dec 6, 2006 | 10:06 AM
lmills's Avatar
It does not matter which one you hook to. They are both connected together with the heavy gauge "hot" wire that runs over top of the radiator
Old Dec 6, 2006 | 09:30 PM
sr148's Avatar
Thanks for the responce guess I will leave it as is..
GR40RCapri
Dec 2, 2006 12:42 PM
gn1270
25
Oct 15, 2006 06:42 AM
BigDave12768
Aug 6, 2006 07:37 PM
Walt L
Dec 25, 2004 10:13 PM
