FASS 95GPH Help
Old Feb 2, 2007 | 05:35 PM
DirtEater's Avatar
FASS 95GPH Help
I orderd a FASS 95 and want to know if it will support 550hp like my dealer told me it would. The reason I ask is, after ordering the 95, I read on another website that the 150 is required for 450hp+.
Thanks for the customer support.
Old Feb 2, 2007 | 06:02 PM
2005 CTD BEAST's Avatar
It will handle it.
Diesel-Dan's Avatar
This system is just fine for your application. Even if you wanted to run the pressure up to 45 PSI this will work as well. BUT i dont see this being needed since that HP level is very easy achieable with just a TST and Smarty/BDDL stack and a good turbo. You got a good kit for what you want to do.
EDIT: Is its a 95 series:
or 95 GPH Pump?
Either way you are fine.........
Old Feb 2, 2007 | 06:52 PM
DirtEater's Avatar
Thank you, Pretty sure the box said 150/95 1006.
Old Feb 2, 2007 | 07:16 PM
RamWheelsBy4's Avatar
Mine holds around 570hp without any problems.
2wheelsup
May 17, 2005 10:45 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
bws
Mar 21, 2005 07:03 PM
