Fass 101
Old Feb 10, 2009 | 05:18 PM
One Way's Avatar
Fass 101
Need some education on the FASS, I have the 95-95, and wanted to know a few things:
What is the recommended interval for changing the fuel filter?
What is the recommended interval for changing out the water separator?
How often do you guys open the drain on the water separator, and do you leave it open it until you see mostly diesel?
What is the procedure for changing the filters? (Do you leave the new filter slightly cracked and bump the ignition and wait for fuel / air purge like stock filter housing?)
Thanks for any info
Old Feb 10, 2009 | 10:02 PM
ratsun's Avatar
I change out my filter once a year but do't drive that many miles (7k ) and never noticed a difference. Separator I never changed? Only drain it a couple of times a year and never yet seen any water. Spin on a new filter (tight) or close the drain on the WS and cycle the key a couple of times, fire it up.
Old Feb 10, 2009 | 10:47 PM
One Way's Avatar
Thanks for the reply, Ratsun when you drain the separator do you open it until it stops flowing?
Old Feb 10, 2009 | 11:14 PM
soulezoo's Avatar
DTR 1st Sergeant
That is not necessary. The water being heavier than diesel, settles to the bottom where the drain is at. It is only necessary to drain until there is no water at all.
I check the water whenever I remember to and, like Ratsun, I have yet to see any water. Just drain into a clean mason jar until you are satisfied there is no water, which shouldn't be much, close the drain and dump the clean diesel back into the tank. If you do see water, then do not put back into the tank, but dispose of properly.
Old Feb 26, 2009 | 08:42 AM
redz's Avatar
fass filter
Hey all, anyone know what filter is needed for the fass system (fuel and air)
and what part# and stores stock them ........ Vancouver Canada
Thanks,Redz
Old Feb 26, 2009 | 09:34 AM
soulezoo's Avatar
DTR 1st Sergeant
Thanks,Redz
Peak Diesel Performance is a FASS dealer and they are located in Langley, BC. Very close.
Old Feb 27, 2009 | 08:25 AM
redz's Avatar
Smile fass filter
Thanks
Redz
Old Mar 2, 2009 | 08:23 AM
Diesel-Dan's Avatar
Thanks for any info
Pretty much all your questions are covered in the owners manual that came with the FASS. Im trying to find one to post up here....i will when i find it.....
Lil Dog
Oct 2, 2004 07:30 PM
gsdog1
Aug 3, 2004 12:25 PM
Haulin_in_Dixie
Apr 20, 2004 11:14 AM
PROSOUTH
27
Jan 27, 2004 12:56 PM
Racer57
14
Jun 26, 2003 06:57 PM
