exhuast install question
Old Dec 6, 2010 | 06:08 PM
farbonciber's Avatar
Going to be installing a 6" stack thru the box. What did you guys use to cut the hole thru the floor of the bed?
Old Dec 6, 2010 | 07:14 PM
madhat's Avatar
Administrator/Jarhead
I have not done it on my truck, but on others I used a rotozip. Make sure to drill a small pilot hole and measure around where you are going to cut... have someone else look too. You never know what you're going to miss, and cutting a hole in a bed is hard to undo...
Old Dec 6, 2010 | 09:16 PM
Thats the only tool I didnt think of... I was really hoping to use the air powered nibbler but with the line-x it was going to be too thick. Didnt think that the air saw would do a good cut, and i wasnt able to find a 7 inch hole saw... Roto-zip it is.
Old Dec 6, 2010 | 10:40 PM
Has anyone tried putting a stack thru a tonneau cover?
Old Dec 6, 2010 | 11:01 PM
madhat's Avatar
I've seen it tried, but not successfully. You'd have to cut a long oval hole to have correct use of a hard tonneau, and the vibration and heat will wreck the cover and mounting bolts. Never seen it on a soft one.
chamisi
Apr 26, 2008 04:18 AM
AKDSLDOG
13
Apr 17, 2006 09:04 PM
turbo_2500
Dec 7, 2005 02:17 PM
1320
Jun 23, 2003 08:05 AM
