Evil Twin Dual CP3 Pump Kits Release Date
Old Jan 27, 2008 | 07:59 PM
  #31
lmills's Avatar
Originally Posted by Caterpillartim
will this kit work if you use two d-max pumps I have two sitting at the shop just waiting for a kit like this to come out it was just a matter of time.
what are you currently running on the truck? If you have a stock cp3 on the truck at this time,all you need to do is use one of those pumps.
Old Jan 27, 2008 | 08:54 PM
  #32
mudslinger's Avatar
Nice kit Lloyd, thanks for the update.
Old Feb 6, 2008 | 06:07 PM
  #33
metal_miner's Avatar
Originally Posted by 94ttss
It is relocated to the back port on the top pump.
If a belt is shredded, can we still put on a stock belt via the OEM belt routing and run off of one CP3 (CP3 in OEM location)?
If yes, how would the ECM read the rail pressure? Will the rail pressure be read indirectly via the rail filling up and then back feeding into the high pressure line from the 2nd CP3?
Old Feb 6, 2008 | 06:17 PM
  #34
lmills's Avatar
yes you can run it with a stock belt in place driving one pump and yes the pressure sensor will still read pressure at that location. It will do just as you stated. It will pressurize that chamber by backfilling it.
Also, I have gotten a lot of guys stating that they would purchase a kit if they could locate a second pump. We do have someone that we have used in the past that has supplied us with numerous pumps for the BETA testing of this. The pumps are used and the price is very good.
Lary, not sure if I am allowed to put in a plug for someones pumps or not. if there is anything wrong with that, just let me know and I will remove it.
Old Feb 6, 2008 | 06:49 PM
  #35
desertchecker's Avatar
Lloyd
I was the first guy out there that I know of to have dual cp3s on a common rail dodge
Joe the owner of PPE here in california , used my truck from the start of his development of the dual cp3 kit for the dodge cr well over 2 years ago
for PPE I know this was not an easy project to complete there was a ton of time and testing fabricating etc before PPE could finally be able to release the twin pump kits to the public or distributers.
I can say that after 24,000 + hard miles I have never had any problems ever to report on the dual pumps
the PPE dual cp3 kit works perfect & the fit & finish is outstanding IMO PPE / Joe did an excellent job on the kit.
all I can say is WOW your kit looks very nice here and it's sure being offered at unbelievable pricing !
people don't realize there is a lot of time and work involved with putting together a kit like that.
congratulations Lloyd for a job well done
it's also nice to see the pricing being offered at a rate that a working guy can afford !
any one considering a modded pump should get money wise and go for the dual cp3 kit , they do work great & reliability with the stock pumps has been excellent.
the kit Lloyd is showing sure looks good & it's a money wise performance bargain !.......
Old Feb 6, 2008 | 08:30 PM
  #36
PEAKSTRYDE's Avatar
What is the "technical" difference in our pumps and the DSNAX?
I have been thinking about adding a DSNAX pump as well.......... any real difference in
2 DSNAX pumps vs 2 of ours vs the stock CP3 and adding a DSNAX??
Old Feb 6, 2008 | 11:58 PM
  #37
lmills's Avatar
Julius, check your mail.
Old Feb 7, 2008 | 12:01 AM
  #38
lmills's Avatar
a lot of people seem to feel that the dmax pump flows more volume than the cummins version. I have never checked personally to confirm it, Either way, with dual pumps there is no real need to worry about fuel flow. You will have plenty.
Old Feb 7, 2008 | 12:07 AM
  #39
jwb600's Avatar
can you tell me how much fuel pressure you would need to run a stage 2 cp3 and another stock pump as a dual setup? would the glacier comp system support enough or do I need a bigger fuel system to run dual pumps? thanks for any help
Old Feb 7, 2008 | 12:11 AM
  #40
lmills's Avatar
the glacier system will not support duals over ~725 hp. Once that level is reached you will either need to add another Walbro into the plumbing, or go to a bigger fuel pump. I personally ran 25 psi for the longest time with this system at idle and had the pressure boost referenced so that the fuel pressure would rise with boost
Old Feb 7, 2008 | 12:31 AM
  #41
jwb600's Avatar
well thanks for the info Lloyd. I guess im going to have to buy that super dog fuel system I talked to you about before no matter what. either I have my pump modded more or get duals im gonna need more fuel
Old Feb 7, 2008 | 11:16 AM
  #42
cquestad's Avatar
I want to check my MAIL!
Old Feb 7, 2008 | 01:35 PM
  #43
jaredb900rr's Avatar
I wish I had the money to be needing to check my mail! This is next (and hopefully last) on the list!
Old Feb 7, 2008 | 06:41 PM
  #44
Bswope's Avatar
Just incase i forget when i stop in tommarrow what is the price on one of these pumps????
Old Feb 8, 2008 | 08:51 PM
  #45
BADBOWTIE's Avatar
This kit looks like a great deal but,,,, I can't seem to find a stock d max pump anywhere but at the *******. Where are you guys getting your extra pumps at?
