engine temp?????
Old May 15, 2008 | 05:18 PM
03dodgeoffroad1's Avatar
engine temp?????
what is the normal spot for the needle to be???? i think mine is a little high and i am trying to find out why it is a bit over the 200 mark on the highway
Old May 15, 2008 | 05:26 PM
tritont's Avatar
Yeah, that's higher than it should be. You might check the fan clutch to be sure it's working. The fan should be hard to turn and shouldn't spin freely.
Old May 15, 2008 | 05:30 PM
i will check but shouldnt there be anuff air coming throught the grill at 55+ so it wouldnt matter in traffic it is fine i forgot to mention that
Old May 15, 2008 | 05:31 PM
ptgarcia's Avatar
Normal operating temp on mine is about 190*.
Old May 15, 2008 | 05:36 PM
tritont's Avatar
if it's fine in slow traffic... it's likely not the fan clutch. Do you have a EGT gauge ? If so, what's it saying at 55+ ? Not sure what to tell you other than a good system flush and some new anti-freeze if that hasn't been done in a while. You could have a thermostat going bad too ???
Old May 15, 2008 | 05:46 PM
well i spon the fan and it had some resiestance and stoped as soon as i let go i did the water pump 2-3 months ago and did the antifreeze then i guess i just have to go and get a thermostat and through that in there on a side note my ac seems to freeze up after a fell miles on the intersate but again in traffic it is fine unless i stop for a long period of time
Old May 15, 2008 | 09:55 PM
dslpwr81's Avatar
Mine runs 200 degrees from day one right off the lot. I have seen it at 210 a lot, and I heard from several dealers that they get phone calls and people comming in all the time concerned about it. They said the common rails run a little warmer and it is perfectly normal according to Cummins. Don't know if thats true, just what I've been told.
Old May 16, 2008 | 12:51 AM
Kman9090's Avatar
According to my edge monitor mine runs between 194-196 degrees and on warmer days will sit at 200. When I run it real hard or am hooked to the sled it will jump up to 220 quickly.
Old May 16, 2008 | 10:00 AM
duallydave's Avatar
im not sure how acurate the stock gauge is,my gauge seemed high so i got a 190 tstat,the old one was a 195,the gauge showed a bit higher with the new tstat,the camander shows 190-193 and 200 pulling,the pod for the x2 shows a little less,i dont know what one is the real temp,a mech gauge with a probe in the engine is probaly the best.no electronics,
Old May 16, 2008 | 10:07 AM
omaharam's Avatar
Not questioning your intelligence here, but if you did the antifreeze, did it run hot before that as well? The wrong ratio of antifreeze to water can affect the temps. You could always use some additive like Redline water wetter and see if that helps. Can't think of the name right now, but in the back of Diesel Power I've seen ads for a coolant you run in place of regular antifreeze that is suppose to drop temps.
Old May 16, 2008 | 10:26 AM
RyeThomas's Avatar
Winner winner chicken dinner!
In traffic on warm days I see 207-210 on average, on the highway once Im at speed it will go down to the 190s but touch the go pedal and she will creep back to the low 200s. Im not worried, my truck runs a little warm no biggie.
Old May 16, 2008 | 10:36 AM
Roperteacher's Avatar
My needle is dead on 200 most of the time in the 07 5.9. Sometimes it will be 190 putting around and I regularly see 210 while pulling heavy loads. My last 3 common rail dodges all ran the same exact spot.
MossyOakCTD
19
Dec 28, 2010 09:11 PM
Racing_Joe66
Jun 12, 2007 05:06 AM
turbox2
Feb 6, 2006 07:44 PM
firesine
Nov 24, 2005 10:58 AM
apache
Feb 22, 2004 05:27 PM
