Edge problem
Old Dec 6, 2006 | 04:34 PM
Booger's Avatar
Edge problem
So I decided a couple days ago to try the Edge/Attitude again. I had ran it before and it caused my truck to shut down so I sent it in and they replaced it with a new one and I sold it and went with BullyDog TrippleDog. The Bullydog worked great and after about 6-8 months for some reason I decided to try Edge again. I can't leave well enough alone I guess. So two days ago I installed the Edge and all seems well but the Attitude monitor changes level settings all by itself. I can be driving and look at the monitor and it will be on "0". Then it will go back to the setting I had it on. I called Edge and they said they knew there was a problem but didn't have a fix yet. Said they could send me a new one but it may do the same thing. So I decided to wait until they figure it out and then switch out with them. They also said that the box was not changing but it was just the display on the monitor. Has anyone had this problem? Maybe it is nothing and I need to quit watching the monitor and just watch the road. Just wandering if anyone else had had the problem. The truck is running fine and I feel nothing different when it is doing this. Thanks to all who chime in.
Old Dec 6, 2006 | 04:44 PM
CG98x's Avatar
Mine does the same thing along with sveral other annoyances which is why it stays set at 0 most of the time.
Old Dec 6, 2006 | 06:03 PM
streetsmoker's Avatar
Mine will do it every now and then. I just ignore it.
Old Dec 6, 2006 | 06:05 PM
SupaDupa's Avatar
Mine does the same thing also. They told me the same story!!! They said they'd have a fix toward the end of the year. Well, that would be about now according to my calculations!!!!!!
Old Dec 6, 2006 | 06:27 PM
aroundhere's Avatar
My TsT changes levels every once in awhile,but never while powered up. It only does it when I restart the engine. One time it maybe the power setting ,next time it'l be the torque setting. I've even had the defuel read off and didn't know it had an off. When it changes the fueling changes acordingly.
I've took off and thought to myself "Self, is this thing haulin a$$ today or what" only to see it's on 7 instead of 4.
I know it's not an edge, but just thought I'd throw in my experience.
Old Dec 6, 2006 | 06:38 PM
sdarchery's Avatar
mine works just fine........never no problems
Old Dec 6, 2006 | 08:10 PM
nathan04's Avatar
Mine does it occasionaly, but I just ignore it.
Old Dec 6, 2006 | 11:17 PM
templer's Avatar
My 06 works just fine, knock on wood! The only problem was when they had version 1 and the 1.1. The 1 made my truck pop through the intake and go into limp mode. Since the 1.1 no probs.
Old Dec 7, 2006 | 06:56 AM
Argo's Avatar
mine does it, didnt know it was a problem. it only does it when I go from full accell to full deceleration.
Old Dec 7, 2006 | 07:43 AM
BlackSunShyne's Avatar
+1...mine only does it when I am backing down, it has never caused a drop in power that I have noticed.
Old Dec 7, 2006 | 09:30 AM
hickeyman's Avatar
Mine does it once in awhile,I also just ignore it.
Old Dec 7, 2006 | 10:36 AM
marc03's Avatar
Same here. Just ignore it.
Old Dec 7, 2006 | 11:34 AM
Argo's Avatar
seemed like it would be a safety feature when letting off the throttle, when I hit it again it jumps right back up to the level it was on, just when backing off.
Old Dec 7, 2006 | 03:20 PM
Booger's Avatar
Thanks guys. I guess I will ignore it as well until they find a fix. I am just a little paranoid after the problem I had with the last Edge Juice on my truck. I'll try and keep my eyes off the monitor and on the road where they belong that way I don't even know it is doing it.
Old Dec 10, 2006 | 05:15 PM
Jus Cruisin's Avatar
I don't have one, but I thought that was what it is supposed to do in order to "back off" the fuel to the injectors. Yes ... No... ?
