Edge/att and Dr.P stack boost pressures.
Old Dec 21, 2007 | 06:32 PM
MegaMagoo3500's Avatar
Question Edge/att and Dr.P stack boost pressures.
I just had the Edge with attitude installed this afternoon. Iam also runing a Dr.P pressure box with it. Now at idle iam seeing 14-15psi for boost and when i start to drive in level 2 i can easyly hit like 46psi and my alert goes off.Now i immeadeatly called back where they installed it and they told me to raise the the turbo alert to 50psi. Well it will hit 50psi again in 4th gear@2300rpm. So they tell me to not to get into it as hard but iam driving it as i did before i brought it in. So iam curios as to knowing if these boost pressures could be out of whack? and if anyone knows how i can rectify this? Thanks. Also should i be worried about these kind of pressures?
Old Dec 21, 2007 | 08:03 PM
BBarnett's Avatar
Something is wrong, i had the edge juice/att with the the hot unlock and the stage 3 dr. performance box and could only hit 42-44lbs. that was on a mech. guage... The attitude tends to lie a little....
It is getting all of its readings from the ecm...Also from what I have been told is that the ecm will not read past 40lbs of boost...
Old Dec 21, 2007 | 11:33 PM
Ill have to get them to check it out. I'll tell ya its a real pain in the butt when they have all the answers for a guy before you roll out of the shop. But when the rollin comes and the questions start to pop to them they ca do othing but draw blanks!!!!
Old Dec 21, 2007 | 11:34 PM
Sorry my N tends to stick at times.
Old Dec 22, 2007 | 12:23 AM
ramtd02's Avatar
unless you can here your turbo screaming at idle...then you have no boost at idle.....which means your map sensor is probably shot....replace it and all should be good
Old Dec 22, 2007 | 12:27 AM
Well thats not what i wanted to hear.Especially when i hear them say" Keep an eye on John Doe because he is still in training"!! While he is THE one working on my truck!
Old Dec 22, 2007 | 09:52 AM
Super Dave's Avatar
Is the Juice plugged into the MAP with the Dr. P plugged into the Juice, or vice versa?
Edge says the Juice should be plugged directly into the MAP with the pressure box (like EZ, etc.) plugged into the juice.
I think the pressure box is fooling the Juice/Attitude that the boost pressure is that high, when the only thing you want it to fool is the ECM.
Old Dec 22, 2007 | 12:01 PM
Thanks Super Dave. I will go out and check under the hood. This stuff is still farly new to me so i appreciate all the help i can get.
Old Dec 23, 2007 | 01:16 AM
ramtd02's Avatar
well it has nothing too do with who hooked it up too your truck....more too do with the electronics of your truck....my rail pressure sensor failed a week ago....i am not trying too blame it anyone....just the fact that electrical equipment will go funny!!!
Old Dec 23, 2007 | 05:01 PM
duallydave's Avatar
ya theres no way you should see any boost at idle,she needs to be under load to get some boost,if your seeing 50 psi theres somthing wrong somwhere,im guessing sensor too
Old Dec 23, 2007 | 07:09 PM
Im sure when i take it back after x-mas they will sort it out for me. If it is a sensor oh well i guess ill be buying a new one.Wanna play, gotta pay!
O.T
Sep 18, 2007 12:50 PM
toupee
Jun 27, 2007 04:19 PM
ocsurf16
Oct 4, 2006 10:19 PM
razor6
Feb 11, 2006 01:28 AM
