Dually Wheel Spacers?
Old Dec 4, 2007 | 04:01 PM
PowerstrokeThis's Avatar
I think I'm gonna go ahead and buy the spacers and if I decide I don't need them then I'll just sell them.I figured that is my safest bet.
Old Dec 4, 2007 | 04:46 PM
homewrecker's Avatar
I might just put the 285's on and then decide on the spacer situation. I can always run the tires at 80psi to control sidewall bulging.
Old Dec 4, 2007 | 05:14 PM
wap's Avatar
wap
I am pretty sure you could run a 1/8-1/4" spacer on the factory lugs if a little clearance is needed. I wouldnt go off of my word though, do some more research before you decided
Old Dec 4, 2007 | 06:02 PM
I'm already running a 1/4" spacer for the 265's. Not enough thread left to put another one. The space on the 265's is okay with 1/4". Have been using this set-up for 6 months now,towing here and there with no issues. I just dont know about the 285's. Will just have to try and see.
Old Dec 4, 2007 | 06:15 PM
06dually's Avatar
What kind of Cooper tires are you running now?? and how much space do you have in between tires with that 1/4 inch spacer?? I am thinking of using a 1/4 inch spacer too with either 265 or 285 cooper stt's.
Old Dec 4, 2007 | 06:38 PM
I'm running Cooper ST's. There's not as much space as factory tires but I feel like its safe towing.My friends have run tires with less space on their 2nd gens for years and never had any problems towing(rubbing),I know I have more space than them(maybe 1/2 -3/4" loaded)It might be slightly more as I am guessing. I dont think the 285's will work , at least not loaded.
Old Dec 5, 2007 | 01:47 AM
RRC's Avatar
RRC
Where did you guys get your 1/4" spacers from???
Old Dec 5, 2007 | 04:11 AM
Most tire shops can get them or ebay.I got a pair for $10 from my tire shop.
Old Dec 5, 2007 | 08:10 AM
abc4yew's Avatar
homewrecker, Me too, I'm running 265 ST's but without any spacer. Even with two forklifts on my 8500# dumping flatdeck trailer...they don't touch when inflated to 80psi. You just have to be careful not to get a stone caught between the tires. Ideally I wish I had an inch of spacing...but I love my 265's ....just wish they were 85 series so they had some height. Kerry
Old Dec 5, 2007 | 09:45 AM
wap's Avatar
wap
Kerry, do you have 17s or could you get 16s on an 03?
I know bfg makes (or did a few months ago) a 255/85/16 in the mt.
Old Dec 5, 2007 | 09:55 AM
The heigth difference in the 285's and 265's is the only reason I'm considering the swap.Like you said,if only somebody would make a 265/85/17.
Sam Turner2
Apr 19, 2007 03:10 PM
98xc800
Jan 11, 2007 06:43 AM
aggieredneck12
Oct 31, 2006 05:06 PM
Original Junior
May 17, 2006 09:45 AM
