dually rear wheel spacers
Old Jul 5, 2011 | 04:29 PM
06dodgedrw's Avatar
right now the truck is an 06, has a 6in lift with a 4in block in the rear. the tires are 265's and have about 3/8" space between the bulge in the tire and the ubolt plate on top of the spring. i am looking to put on either 35x12.5 or 37's bfg km2's. i know i need a 2" spacer between the 2 tires but do i need a spacer between the inner rim and the hub or will they clear with out rubbing? just trying to keep them in as much as possible they kinda frown on them sticking out alot around here. any help with this set up from some 1 with this set up would be greatly appriciated so i dont spend a butt load of money and not have it work and any pics of this set up will deffinatly help such as how much they stick out and the gap on the plate and springs. thanks for the help
Old Jul 9, 2011 | 04:06 PM
06dodgedrw's Avatar
or what type of spacing would be required to run 285/75's i know ill need a 1.5" spacer between but do i need any thing on the hub
Old Aug 1, 2011 | 09:35 AM
06dodgedrw's Avatar
Any 1 have an idea just dont want to spend big bucks on the 285's and not have it work just want to keep them in the wheel well as much as possible so was thinking like a 1/4in spacer on the hub and the 1.5 in between. Will it work that way the inner rim is still hub piloted
Sam Turner2
Apr 19, 2007 03:10 PM
98xc800
Jan 11, 2007 06:43 AM
aggieredneck12
Oct 31, 2006 05:06 PM
Original Junior
May 17, 2006 09:45 AM
