Dual Stabilizers....whats everybody runnin'
Went to 4 Wheel Parts at lunch today to buy the Superlift Dual Steering Stabilizer with the Bilsteins. They told me it would not work with the Mag-Hytech diff cover. Clearance issues. So I bought a single Rancho RS5000. When I got back the office I called Defiant. They have a new dual coming out in February that WILL WORK with the Mag-Hytech cover. I can't wait. I will be the first in line for one of those.
Defiant trussguard.
The Defiant setup w/Radflo's has to be seen and experienced to appreciate. Paul build's a good product. He's got a less expensive one for $404. The trussguard is thick plate and powdercoated and actually fits. All the dual setups seem to have a common goal: lift the shocks up into a line parrallel to the axle shafts.
I added a set of Skyjacker dual opposed in-lines on mine. They look to be a little low, but by modding the mount just slightly, they mounted in addition to the oem unit, so now I have a triple stabilizer set up. Also, with the 34.5" tires I had a little extra room anyway. This setup works well, controls really heavy tires and wheels (265/70R19.5's with steel wheels) and doesn't seem to affect return to center (I was afraid I might get too much dampening and adversely affect return to center, but it didn't.)
I second the THUREN FABRICATION single fox stabilizer i have 06 w/6inch lift and bilstien 5100 shocks and it works perfectly besides don has the best customer service of any company I've ever seen.
just wondering- is everyone who is running the superlift dual bilstein set up actually running bilstein 5100's or did you just order the upgrade from superlift, which uses edelbrock shocks that look very similar to the 5100's?
is there a single bilstein ss replacement? i would like a dual ss with bilsteins but i dont like that the superlift one has flames on it i would like a plain one like the skyjacker but just with bilsteins
