Dual Pod With Grab Handle with Pics!!!
Old May 3, 2007 | 01:22 PM
  #31
Luvnacumns's Avatar
THat will work. I will go and paint carhartt's fender flares and then meet up with you christian. I still have your address so I can plug it into my gps and get there. Carhartt I need your addy. I will come up early sat morning Probably leave here about 6!
Pm Me your address and the paint code is PBJ. Correct..
Be on the looke out for an A5k write-up!!!
Shane
Old May 3, 2007 | 04:13 PM
  #32
jwb600's Avatar
shane you should get a patent of some kind and sell them. hopefully you make millions of them. I would like to find a way to make some big $
Old May 3, 2007 | 04:43 PM
  #33
Luvnacumns's Avatar
That would be nice but it's mainly a hobby.
SHane
Old May 9, 2007 | 11:04 PM
  #34
Luvnacumns's Avatar
Updated and Fixed!!
Well I test fitted the first one and she was off just a hair and wouldn't fit soooo back to the drawing board and now it's good to go!! Off to it's new owner..
Shane
Old May 9, 2007 | 11:26 PM
  #35
kawiram's Avatar
Ooops!
Please dont sue me Shane! Not quite finished, needs one more layer of fiberglass, and final sanding, paint, yadayadayada. Thought I got a universal pod, but it turned out to be from a mustang. Cut it up anyways, just meant it'd need a little more fiberglass. Thanks for the sweet idea Shane! I'll post more pics when it's finished.
Old May 10, 2007 | 08:07 AM
  #36
Luvnacumns's Avatar
Sue you that's funny... . Just a tip you'll want to smooth that bondo out or you'll have a nightmare on your hands. It helps to smooth it when it's just past it's hardening stage.. When it's right there at the soft/hard stage!! Once it's cured and hard when it's rough it's hard on sanding pads!!
Shane
Old May 10, 2007 | 08:17 AM
  #37
53 willys's Avatar
NIce work boys
Old May 10, 2007 | 08:55 AM
  #38
goodeyesniper75's Avatar
what are you guys painting these with? since it will be smooth wont you have to do the othere side to match.
Old May 10, 2007 | 09:04 AM
  #39
Luvnacumns's Avatar
Once the process is done there is a texture coating you can get to match the factory texture to an extent it's not exactley but it's close enough!!
I'll have pics of it mounted with guages in it later tonight!! Then it's in the mail!!!
Old May 10, 2007 | 09:34 AM
  #40
o cool...i have the srt-10 pillar, i am in the prosses of adding one or two more guages to it and thats what was holding me back...thanx
Old May 10, 2007 | 09:57 AM
  #41
53 willys's Avatar
hurry up!!! ever sense I pulled my gauges out I feel lost....I keep looking for my pyro and it's not there
Thanks for making this Shane.
Old May 10, 2007 | 12:46 PM
  #42
kawiram's Avatar
Thanks, it's not bondo though. It's fiberglass, After I get another layer of glass on and smoothed out I'll probably use Bondo to do the final smoothing. Oh, question. Did you cut off any of the two flat clips that pop in there? Dont want to trim it off but might have to fow the guage wiring.
Shane
Old May 10, 2007 | 01:09 PM
  #43
Luvnacumns's Avatar
Yep I had to take a flat clip off!!
Shane
Old May 10, 2007 | 10:52 PM
  #44
Luvnacumns's Avatar
Only had one guage but you get the point!!! I am sure Mark will post pics when installed!!
Old May 10, 2007 | 11:24 PM
  #45
53 willys's Avatar
Sweet I am stoked I will post pics soon
