Does a edge juice attitude have to match your axle ratio?
Does a edge juice have to be programmed for your axle ratio? I have a 2004.5 dodge ram 5.9 cummins.(325 HP) Is mine the HO 600 series engine? anywyas can i just buy any edge juice attitude for my 2004.5 ram? is it ok to buy a used one? Do any edge juices accept internet updates and have turbo cool down mode?
no, its readout is based on tire RPMs, rear end ratio would only affect the speedo in the dash.
yes.
it has to be for the 04-05 HO engine, not just any one will work.
yes.
no, you have to mail it to Edge for any updates. if you get one that is an outdated version they will update it for free.
not that I'm aware of.
yes.
Actually, the answer to this one should be "Yes"...there is an option in the Attitude that wants to know whether or not you have 4.10s or 3.73s...I could definitely tell a difference when I switched between the two...my defueling was all jacked up, etc...I would set it to whatever gears you have.
i got one on my truck which is the same as yours, the turbo timer is a upgrade and have to pay edge $50 for it.. when i sent in my edge w/attitude that was a version 1.0 , i got a 3.1 back.. but no turbo timer, you have to pay for the turbo timer upgrade.
never seen the parameter for different axle ratio in the setup.
sallyman1
Apr 25, 2011 08:45 PM
Fire Rescue124
Jul 9, 2008 08:48 AM
Redog76
22
Feb 6, 2008 10:32 PM
sallyman1
Dec 4, 2007 01:06 PM
