DIY CP3 mod
Old Feb 28, 2007 | 10:24 AM
53 willys's Avatar
Originally Posted by banshee
These two mods, plus a couple other small mods, would constitue a Stage 1 upgrade. I don't think you'll see much more than 15-20 HP, but it does help. I modded my FCA somewhat differently than the one in the article, but it's not in a way you can do it with a dremel. A Stage 2 pump is comprised of different internal changes to increase the pump's displacement per revolution.
so I'm guessing a Stage II would have bigger plungers???
Old Feb 28, 2007 | 11:16 AM
banshee's Avatar
Yes, the other mods are as simple as the ones listed in the article.
Larger plungers and/or a higher lift cam for the stage 2.
Old Feb 28, 2007 | 11:51 AM
rockcrawler304's Avatar
It's incredible what some companys charge for such an easy mod. Not just the CP3, I have seen people figure out many things that others end up paying top dollar for.
Old Feb 28, 2007 | 12:14 PM
tauberson's Avatar
Anyone know where to get a replacement valve for the FCA ?
Old Feb 28, 2007 | 12:21 PM
OldSmokey's Avatar
Is that just in case tauberson or do you need one already?
omaharam's Avatar
You can't attach a hp figure to a cp3 - stage I or II. It does not add HP. It allows your power adders to do their job to their fullest. It's lke exhaust. Adding exhaust does not ADD power, it FREES UP power. So a modded pump will ALLOW whatever hp you are losing due to insufficient supply.
Old Feb 28, 2007 | 12:23 PM
OldSmokey's Avatar
Yah i tried calling Chris at relentless earlier but he was putting in a clutch. I am courious what mods were on the trucks that they saw 86 and 120ish hp gains with this mod.
Old Feb 28, 2007 | 12:31 PM
Billy Ram's Avatar
Originally Posted by Dan Marino
Am I understanding the info correctly ...those steps are what makes a CP3 modded and worth $1100?
I believe the pump is remanufactored and modifyed for $1100 with a warranty.
Old Feb 28, 2007 | 12:32 PM
tauberson's Avatar
Just in this case. I was thinking of getting one and modding it prior to pulling mine off. That would aslo give me a backup incase i botched this one
Old Feb 28, 2007 | 12:33 PM
Dan Marino's Avatar
Here is something...why doesnt someone sell a modified metering valve kit for the FCA? How bout that one...
Old Feb 28, 2007 | 12:37 PM
OldSmokey's Avatar
I dont know guess they think theres better money in selling a whole new cp3.
Old Feb 28, 2007 | 12:38 PM
tauberson's Avatar
A little more info on CP# and fueling.....http://www.oilburners.net/forums/arc...hp/t-9534.html
Old Feb 28, 2007 | 12:43 PM
tauberson's Avatar
some more ----http://www.cumminsforum.com/forum/3rd-gen-tech-articles/1262-cp3-fuel-system-explained.html
Old Feb 28, 2007 | 01:09 PM
Dan Marino's Avatar
You know, there is something I dont understand about the article(s) that Chris wrote over there....He goes through how to mod and has pictures and everything and says this is the same thing that some companies charge 1100 for...and then in another article he is downgrading a modded single and says "There's very limited gains to be had there." and "The twin pumps are the only way to go."
So why waste all the time and energy on the modded single writeup? Whats up here?
Old Feb 28, 2007 | 01:29 PM
OldSmokey's Avatar
I just got off the phone with Chris about this and he said that he put this up because its basiclly old news. We wanted to give something back. He said that with all the new dual, hyperdrive, cp3.4, or stage two and three cp3s he said that this is actually very old news. I asked him about gains and he told me it should allow for the use of another level on the TST. It really depends on the truck. I think he may have wrote the article well before the dual cp3s were out. So i think that may be why. Does that kinda answer your question Dan.
