difference between the 2004 motor and 2004.5
Old Feb 24, 2006 | 12:21 PM
razor6's Avatar
im tryin to get rid of my banks and i have someone that wants to buy it but im not sure if his motor is the new 610... it said on his engine that it was manufactured in may 2004 and im pretty sure its the 610 but i think one of his sensors is in a different spot. but its the same sensor. i didnt get to take a long look at it but maybe there is something written somewhere that can tell me whats what... thanks
Old Feb 24, 2006 | 12:27 PM
CRXsi's Avatar
Any truck built after Jan/04 will be a 600 series. If you want to verify there should be a sticker on the drivers side of the valve cover that states engine serial number as well as build date and engine HP. If it says 325hp then it is a 600 series. If it says 305 the it is a 305/555. But starting Jan/04 (truck build date) was the date that all 600 series trucks were started.
smokindog's Avatar
The '04's are 305/555 rated and the '04.5's are 325/600 rated. That's not the only difference though.... the '04.5's have that wonderful 3rd injection event to keep emissions low.
I would call your beloved Banks and ask them if the product is compatible with the other truck. You might actually get to speak to someone this year since it is only late February....
Bookshelf
May 18, 2011 04:20 PM
gman2310
Oct 25, 2006 03:02 PM
SPINPOSI
Aug 24, 2006 10:44 PM
bmallen
Feb 29, 2004 10:30 PM
jet
Nov 16, 2002 09:32 PM
