daul feed lines
there are plenty of US dealer who can make that hose....but it has to be that parker High pressure line.
I actually called Parker to find out where I can get one made they told me all I needed to know was the fitting sizes and configuration, and they could make me whatever I wanted...the more I looked the more I saw guys who had it saying it was not worth it...so I never bothered
Parker is the ONLY (that I found)company that makes them...IIRC its called parker proflex or something.
they are used for water jet cutting is what Parker told me but are still rated for diesel.
Pretty sure you can't just get one made at a hydraulic hose shop. It's been said before that nobody in the U.S. can build a line that's certified for these kinds of pressures.
It makes sense to me. Those two seperate flows have to collide somewhere. Doesn't the dual feed line also cap off the return line?
No, a hard line made at ahydraulic shop is what i was referring to. I know I did not specify, but that is what I meant.
I am glad it makes sense to you, wish that it did for me. I would HAVE to think the line did not cap off teh return. Especially with that much pressure, there is always going to be fuel that is un-used. To cap it off would be insane.
Two seprate flows? What about on a high HP fuel setup on a V8? It will "Y" before teh fuel rail, and will have 1 line feeding a rail on one side of the motor, and 1 line feeding the other side. Then after the rail, they are joined back up. You have 2 seperate "flows" there, and no problems.
here is the thread I was reading.
https://www.dieseltruckresource.com/...dual+feed+line
Trying to compare our fuel system to a high HP V8 is apples to oranges. A FI gasser system runs what, 40-80psi? That's about 24,920psi less than what we're talking about here.
Was not aware of the hard line, thanks for teh tip.
I know it is less pressure
but we are still talking about the same principals. Explain it to me then, how does it work (or why does it not)? I mean, if you do not even know whether or not teh return is capped off, how can you possibly know what is happening inside the fuel rail?
One thing I know is that two sources are flowing into the rail and colliding at 25k+ psi. There is no "Y" involved.
EDIT TO ADD: Just went out and looked at my rail. The line replaces the RV. There are no other outlets on the rail so it's basically capped if you install the line.
I guess I could ask you the same question, eh?
Ask what question?
Huh, ok then. Well, THAT makes more sense with no return. Your theory makes more sense at that point since fuel has nowhere to go. I was under teh impression that there was a return, and that is why it did not make any sense. With no return, where is all the fuel going at part throttle, idle? I can see the "colliding" effect @ the pressures the fuel system is seeing, and for nowhere to go I can see problems. The fuel has to go SOMEWHERE.
You guys talk about the pressure of the hydraulics, what about the rock crawlers? Granted the buggie or truck is very lite, but still you would have to turn all 4 say 39" tires from a dead stop and bein wedged in a crevice etc. I would think the hoses to the rams would have to under alot of pressure? Just my opinion.
I work on these at work...everything on them is hydro. IIRC they dont even run at 5k psi
http://www.fmctechnologies.com/Airpo...mmander30.aspx
it's not, it's more like 2000psi max. a full hydro steering does not even come close.
And there you have it
53 to the rescue again
