control arms
Old Jan 2, 2007 | 02:06 PM
goodeyesniper75's Avatar
control arms
who makes adjustable control arms?
Old Jan 2, 2007 | 02:33 PM
Cowhand's Avatar
Why would you need them? You can get 5+* out of the OEM adjustment cams....
Old Jan 2, 2007 | 02:45 PM
blcoonrod's Avatar
Superlift makes them. They are called the rockrunner arms.
Old Jan 2, 2007 | 02:47 PM
ptgarcia's Avatar
Do you just need longer arms? I'm not sure I'd fuss with adjustable arms if you only need longer arms.
Old Jan 2, 2007 | 03:26 PM
Just Wondering Because I Need 5*+ And Im Not Sure If I Can Get It With The Rockrunners.
Old Jan 2, 2007 | 03:29 PM
ptgarcia's Avatar
Just curious, but why do you need so much caster?
Old Jan 2, 2007 | 03:56 PM
Cowhand's Avatar
Pauly, he's chasing DW.
goodeyesniper, how much caster are you running now? 5* is quite a bit, I ran 3.5* when I still had the 4 link.
I run 2* now, no steering stabilizer and no DW. The again, I ditched the 4 link.....
Old Jan 2, 2007 | 04:02 PM
ptgarcia's Avatar
Oh, I see.
I don't think overdueing castor is the answer. It may mask the problem but its not the answer. If all your links and arms are sound I would take a hard look at your tires. Even if they are brand new and balanced perfectly if worth a shot. Good luck!
Old Jan 2, 2007 | 04:23 PM
Cowhand's Avatar
Actually, caster usually IS the problem. The technical term for DW is "Caster Shimmy". Worn steering/suspension components and bad tires just magnify the symptoms.
More caster will usually cure it, but it gets to a point where it affects the steering and it's hard on the ball joints.....
Old Jan 2, 2007 | 04:32 PM
ptgarcia's Avatar
Understood, it just seems going past 5* is that point. 5*+ is a ton of castor, more than twice as much as should be needed.
Old Jan 2, 2007 | 04:44 PM
no_6_oh_no's Avatar
With that bumper, the lift, and those tires not sure just caster is going to cure it. Check out the following link for adjustable arms and steering stabilizer.
http://www.solidsteel.biz/
That much caster is hard on about everything in the front end including the drive lines. Good luck on figuring it out.
Old Jan 2, 2007 | 06:20 PM
Cowhand's Avatar
'zactly......
Old Jan 2, 2007 | 07:10 PM
Outlaw Diesel's Avatar
There is a place called Top Gun Customz based out of Tenn. They have them for under $200. I have done business with them before and had no problems. Check them out, www.topguncustomz.com.
Old Jan 2, 2007 | 08:20 PM
morkable's Avatar
I fought with dw for several months, checking this, checking that, rechecking this and that,, then buddy of mine that is a dc mechanic went for a ride with me, without even knowing what I had done, he immediately said that it was a lack of castor. So I went to another fellow that I know, he is the alignment tech for another dc dealer here. He told me that everytime he does a wheel alignment on a dodge truck now (with a diesel) he automatically goes to the max castor that the stock arms will allow. which is in the 5 degree area. Since he has done mine, it has been good. I hit a bump that normally would have had me bouncing off the road into the ditch at about 100 MPH and no dw..,
Kevin
Old Jan 3, 2007 | 07:37 AM
yea the dss is somthing that i would like to get in the future.
