Clunk After Leveling Kit?
Old Apr 2, 2011 | 08:48 PM
EdmontonCanada's Avatar
I just had my ball joints replaced including tie rod ends. U joints are fine.
I had my truck in for service because of a clunking noise in the drivers side when turning left quickly.
I'm wondering if it could be the suspension. I had coil spacers installed a few months ago. So I'm wondering if something could maybe be loose on the drivers side? If so, what?
The guys at the shop had a hard time installing the coil spacers because I also have a Carli Starter suspension system.
Old Apr 3, 2011 | 08:02 PM
firemanram's Avatar
Track bar bushings
Old Apr 4, 2011 | 06:27 AM
kry226's Avatar
Originally Posted by firemanram
Track bar bushings
This. Try tightening your track bar at the frame on the driver's side. Needs lots of torque.
Old Apr 4, 2011 | 07:41 AM
HotRodK's Avatar
Question
Ive had this same issue after leveling kit. Thought it may be the sway bar end link. ??
Old Apr 4, 2011 | 02:32 PM
patmac919's Avatar
I had the same "clunk" you described after switching out my stock trackbar for an adjustible one; was sure I had really tightened the bolts as well as I did after putting in a leveling kit last year. Finally got somebody to look under the truck as I slowly drove forward turning the steering wheel one way then another. He spotted the ever-so-slight shift in the track bar at the mounting point. I got under and was able to get another half turn out of the nut, and the noise has not come back. For the small amount the track bar shifted, it sure sounded like something much bigger was happening.
Old Apr 4, 2011 | 08:12 PM
jimbo486's Avatar
The holes in the track bar's frame bracket have been known to oblong. This kit from Source Automotive could be used as a fix.
I assume the tabs should be welded to either side of the existing bracket.
Old Apr 5, 2011 | 07:54 AM
HotRodK's Avatar
Talking
So I did this yesterday and what do you know... IT STOPPED! Your awesome!!
Thank you so much!
Old Apr 5, 2011 | 03:17 PM
gpshemi's Avatar
Had the same issue after mine. The hole was slightly wabbed out too. No 20k later it's back. I fear I'll have to go to the washer fix above. Keep it in mind down the road.
Old Apr 6, 2011 | 07:02 AM
kry226's Avatar
Thank you so much!
Glad to help. I had the same issue before and the same fix cured it.
Now the other guys are correct too in that if this continues to occur, you need to look at a potentially bad bolt where a new bolt held torque better (heard of this before and it's the cheapest fix other than tightening), or the hole becoming worn and allowing a shift of the track bar regardless of how tight the bolt is.
Cummins610
17
May 29, 2010 12:50 AM
MasseyMan1089
May 23, 2007 07:56 PM
Honkylips
Jun 1, 2006 09:32 AM
dpeder
Feb 21, 2006 11:34 AM
oregon ram
Jul 21, 2004 06:11 PM
