Cleaning head
Old Aug 22, 2008 | 10:03 PM
06 DIESEL's Avatar
Cleaning head
I am in the process of replacing my head gasket and I was wondering what is the best method to clean the bottom of the head and top of the block from old gasket material and carbon build-up. Thanks for all recomendations.
Travis
Old Aug 23, 2008 | 03:11 PM
Dwitt0187's Avatar
i mild buffing wheel on a grinder of some kind and the spray gasket remover
danny
Old Aug 23, 2008 | 03:41 PM
53 willys's Avatar
we use a angle grinder with a red 3m scotch brite pad....dont bare down on it tho, or use a razor blade
Side note~never use the angle grinder on a alumnuim head...our CTD cast metal heads are ok tho.
Old Aug 23, 2008 | 03:45 PM
lmills's Avatar
scotch brite pad and wd40
Old Aug 23, 2008 | 07:31 PM
dundun98's Avatar
Non-clor brake cleaner to soften chunks, then a 90 degree mini air angle grinder with a greeen 2 inch Scotch Brite bristle pad. This combo is the bomb for gasket removal.
Old Aug 23, 2008 | 07:58 PM
PourinDiesel's Avatar
What Lloyd says.
I would advise against grinders and powered tools to remove gasket material from heads...
It does not need to look brand new just make sure it is cleaned up.
Old Aug 23, 2008 | 09:25 PM
53 willys's Avatar
as long as the scotch brite pad is not the really course one air angle grinders are fine...but never use power/air tools on a aluminuim head.the green bristle bush pads like dundun98 posted are AWESOME too...
I guess the cr heads wont take much anyway since they use the MLS gasket...hand pads would probaly be enough to clean it good.
Old Aug 24, 2008 | 06:24 AM
lmills's Avatar
Originally Posted by PourinDiesel
What Lloyd says.
Yep, thanks Justin for the tip. LOL You gave that to me over 53,000 miles ago and this stock head gasket has held every since.
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
Dusty Ratcliff
Apr 10, 2006 07:35 AM
MADSEN
Oct 7, 2004 09:43 PM
OT-OF-Here
Aug 7, 2004 07:56 PM
