carnage from the wall of shame...
Old Aug 30, 2007 | 05:50 PM
tritont's Avatar
Thanks Keegan, you're welcome too. Here's a couple more to go with it if they'll help...ya gotta get to that meltage
Old Aug 30, 2007 | 05:54 PM
UnrulyNFS's Avatar
Wow, who tore your motor down? That was nice and organized. I don't even recognize some of those pieces.
Old Aug 30, 2007 | 06:01 PM
tritont's Avatar
I did. I wouldn't say I'm **** but, I do like to be somewhat organized
Old Aug 30, 2007 | 06:04 PM
UnrulyNFS's Avatar
I'll definately use some of those pics. I'm gonna go to Commerce and try to video some too. Should have some good stuff for more videos in the next couple of weeks.
Old Aug 30, 2007 | 06:08 PM
tritont's Avatar
cool, be sure to stop by and say hi if you see my truck. I plan on running if I can get my truck tuned. Thanks to Bob W, Don M & Rip R so far in helping me get there ! Looks like us 3rd genners really need someone to write a good program to not fuel so much on the bottom and give it all it has up top.
Commerce is where I fried the piston
Old Aug 30, 2007 | 07:09 PM
cbrahs's Avatar
Ty,
going to have to put your right foot on a diet!!
Old Aug 30, 2007 | 07:30 PM
UnrulyNFS's Avatar
Will do. I sure hope I got my truck back by then.
Keegan
Old Aug 30, 2007 | 09:29 PM
Luvnacumns's Avatar
WOw killer pic's!!! now I'll have them in the back of my mind when roasting the tires!!!
Keegan it's about time you got another killer video out!!!
Old Aug 30, 2007 | 10:48 PM
jwb600's Avatar
when my pyro gets about 1400 i let off doesnt matter what im doing. i had it buried when I pulled one time but only ran the tst on low settings. my truck is an 06.5 and I run the tst R37 ive been having some issues with it also. they gave me some new harnesses today to see if thats the issue. I hope it is. man that makes me sick seeing burnt pistons and stuff I hate that
Old Aug 30, 2007 | 11:10 PM
abc4yew's Avatar
It doesn't take 2000degrees to do that.....1500 and keep adding fuel and the pistons will burn if you don't blow it out with lots of boost...stock turbo.....awesome carnage. I don't think the TST was the fault...and even with it on 2/0 and a downloader... If you are measuring and controlling EGT's with air and water...they are ok...All those injection events can add up to a lot of combustion is you start adding duration and timing to each one. KS
Old Aug 30, 2007 | 11:14 PM
tritont's Avatar
they didn't tell me that directly either. It was a forward from someone they did tell. I called and asked Mark about it and he said that was correct.
He also said that it does work on some trucks and not on others, they weren't sure why. Mine and yours it seems to have worked on but, to be safe... I wanted to take it off and Mark suggested it too.
all I can say is be careful ! part of the problem is the TST adds timing "along" with the stock timing. It should replace the stock timing and do it itself. Both working together is more than the truck can take.
Old Aug 30, 2007 | 11:22 PM
tritont's Avatar
It was a combination of a few things I think. I ran the TST on 2/0 and several different smarty programs for 6 months before this happen. That's why I would agree the boxes weren't totally to blame. I believe #4 injector stuck open because of the combination of events, my foot and letting the EGT gauge bury.
I bet it was close to 2K in the cylinders !
Old Aug 30, 2007 | 11:58 PM
jwb600's Avatar
so its just 2/0 that is the bad numbers or anything higher than that?
I noramally run mine on 1/1 up to 4/1 but not on 2/0. on the street I really dont even run the tst unless ive got someone who wants some
Old Aug 31, 2007 | 01:01 AM
tritont's Avatar
it's 2/0 and higher. Something happens with the injection/timing event that they can't control. I hope they don't stop trying... I want my box back !!
Old Aug 31, 2007 | 12:13 PM
jwb600's Avatar
well I appreciate that info. I saw your big rig at IRP at the diesel nationals but didnt know who to look for but knew it was your truck. If I put it back on the levels will stay low. I wish they would get it figured out also. I told them I need the tst to get the power I want. I know there are other boxes out there but this one really helps out. I have to find a daily driver before I can get to extreme
