Can i stack a Module and a Programmer?
I just put larger tires on the back of my truck, i took it to the dealer to recalibrate the spedo and its still wrong, i took it back and thay told me thay couldent get it " perfect " .... So, im looking at buying the superchips flashpaq for my truck so that i can fix the tire size BUT, i dont want to buy a $400 dollar programer JUST for tire size, I want to be able to Use it.. http://www.xtremediesel.com/index.as...ROD&ProdID=966 Heres my second deal, I allready have a stage 3 predator module on the truck, http://www.autoanything.com/performa...0A1901465.aspx .. My question is can i run that module and and program the computer with that flashpaq to performance and have them boath work right with each other? I had a guy tell me i can do this but i just want to do my home work.. If someone can tell me someting id apreciate it. Thanks! - Caleb
For the most part, if only one adds timing (and possibly pressure also), theres a fairly good chance that it may work. However, some programmers/modules/downloaders/boxes/what-have-you just dont like playin with each other on differing trucks (i.e. Edge Juice and Smarty work on some trucks, but not so well on others)
if you just want a programmer for tire size, there are some out there that only do tire size and nothing else. they sell for about $150 but always check your actual mph against something like a gps, as most programmers are off by as much as 30%.
I have a flashpuke and a striker stage I,probably would be ok but if I could do it again*** SMARTY****
cemt8
Sep 29, 2008 09:27 PM
john.overton
Nov 15, 2007 12:16 PM
morkable
Feb 15, 2007 10:23 AM
TorqueJunkie
18
Aug 30, 2006 11:51 AM
thecatsfan
Feb 11, 2004 01:58 PM
