Can I get a Monitor instead of gauges?
Old Sep 13, 2005 | 11:51 AM
whatdieseltoget's Avatar
Is it possile to run a Monitor, like the Edge Monitor or the Bully dog and not have to use thier programs? I like the look of amonitor more than gauges. I plan to do a TST powermaxcr stack with an edge EZ in the future. What are my options for a monitor? Thanks.
Old Sep 13, 2005 | 12:05 PM
B.Law's Avatar
The Bully Dog unit can be used by itself, i'm not sure about Edge's. I only know about what I own. If you are interested in the Bully Dog's unit I will give you a good price on mine, I have it mounted in the SRT pillar. I am just thinking about going back to analog guages...
Old Sep 13, 2005 | 02:24 PM
RamWheelsBy4's Avatar
The Edge Attitude monitor will only work with the Juice module installed. It is not a standalone monitor.
Old Sep 13, 2005 | 03:15 PM
deezulsmoke's Avatar
You can also get a palm PDA with software to monitor your engine outputs. You can use this with anything.
Old Sep 13, 2005 | 03:20 PM
Nate-03 D's Avatar
How is instalation of the monitors compared to the analog gauges? Do you have to do any drilling into the manifold or anything of the sort, or is it just plug & play per se?
Old Sep 13, 2005 | 03:22 PM
You still have to install a pyrometer and boost line, so yes you do have to drill and tap your manifold for the pyrometer. It is a pretty simple install though.
Mike L
33
Aug 9, 2010 11:30 AM
guitarman
Mar 15, 2009 11:18 AM
sro140
May 28, 2008 08:55 PM
nitis
Feb 26, 2007 07:38 PM
