Can '06 pinion factor be adjusted?
Old Jan 29, 2006 | 09:47 AM
v8440's Avatar
Hi all,
I have heard that 06's can't have the pinion factor adjusted for different tires/gears. Is this true?
Old Jan 29, 2006 | 10:10 AM
mikmaze's Avatar
thats not how you want to do it, there is a menu in the comp for abs, in there will be a setting for revolutions of the tire per mile, works well for changing tire size- but not sure how well it would work on a gear change?
Old Jan 29, 2006 | 11:05 AM
v8440's Avatar
Ok, so you're sure that you can in fact compensate for changing tire size on the 06's? I lumped gear change in with my original question mainly because I assumed it would be the same process to account for that. I won't be doing that, but if my '06 doesn't sell then I would eventually put taller tires on it. I'm just wondering if what I heard was correct, that the 06's can't be adjusted for different size tires? I know the earlier ones can...
Old Jan 29, 2006 | 11:10 AM
Deuce's Avatar
On my 06 when I put larger tires on it the pinion factor wasnt changed as was done a my 03-------you have to put in the tire size you have on the truck. I didnt believe the tech and he showed me the prompts and it asked for tire size.
JIM
Old Jan 29, 2006 | 02:48 PM
4x4not's Avatar
Unless Dodge dramatically changed something, the '06s should be the same as the '05s for the speedo. It is all computer driven off the ABS tone ring and go by revs/mile. The only thing that can effect it is changing your tire size. Not gearing, not trans.
Tiara3100
Apr 6, 2008 10:31 AM
BLACKDODOGE
Dec 7, 2005 09:33 AM
hognutz
Nov 28, 2005 12:16 PM
CSAGrey1
Sep 14, 2005 07:39 PM
Geographic Void
13
Sep 8, 2005 04:00 PM
