Cab light install ????
Old Dec 31, 2006 | 06:15 PM
Luvnacumns's Avatar
Where do I place the template and how far back does it go??? Looking from the instructions you place the front arrows pointing at the line onthe front of the window and then center the lights... From that point it looks like the center light will be drilled through the overhead light??? Should it go back farther can anyone with a cab light kit install go out and measure how far back the lights are from the glass???
Thanks Shane..
Got everything ready to go I just need to know exactly where i need to drill... Also how deep do I need to drill so I can set a depth on the bit..
Old Dec 31, 2006 | 06:30 PM
Festus's Avatar
from the top glass edge to to the rubber light grommet on the centre light is almost bang on 4 inches on mine. Hope that helps.
Old Dec 31, 2006 | 07:02 PM
Luvnacumns's Avatar
Thanks...
Got too dark so I will finish install tomorrow.... Also The green wire where do I tap into??? I have read there is a place onthe passenger a-pillar white and black wire... And the black wire with the round loop I asume ground into the overhead?? The instruction's I got are s**t!! Just pic's and poor ones at that..
Thanks Shane
Old Dec 31, 2006 | 07:16 PM
Festus's Avatar
Originally Posted by Luvnacumns
Thanks...
Thanks Shane
Sorry, can't help you there. I ordered mine with, so I didn't do the install.
Old Dec 31, 2006 | 07:26 PM
Luvnacumns's Avatar
I though all 3500's come with the lights.... I was a little disapointed in that... Oh well gives me something to do.... Thanks Festus..
Old Dec 31, 2006 | 07:54 PM
lehall's Avatar
Seen this ?
https://www.dieseltruckresource.com/...d.php?t=129778
Old Dec 31, 2006 | 08:03 PM
Luvnacumns's Avatar
Yep, Looked up most of them on here.... Thanks Shane
Old Dec 31, 2006 | 08:13 PM
t-boe's Avatar
I'm in the same boat. I got a set for Christmas. Just got to put them on. I just hope I drill the holes right on. Don't want to goof on a new truck.
Old Dec 31, 2006 | 08:18 PM
Luvnacumns's Avatar
t-boe... I am going to a friend's tomorrow that has them installed allready so I can take measurements.. I will let you know tomorrow so that it helps.. I would take pics if my **** camera wasn't lost!!!!!!!!!!
Shane
Old Dec 31, 2006 | 08:26 PM
d0dg301's Avatar
I know on mine that when I pulled my headliner down ther were five mounts under that, that are from the factory. All that I had to do was center my drill in the holes and that was that. Pretty simple.
Old Dec 31, 2006 | 08:44 PM
t-boe's Avatar
Shane
If Idaho wasn't so far I'd let you borrow mine . Thanks!
Old Dec 31, 2006 | 10:38 PM
Luvnacumns's Avatar
I hear ya there... I might go get my dads. He never uses it anyways... Had it two years and it's still in the box...
Old Jan 1, 2007 | 10:08 AM
Thundercloud's Avatar
There is this site that might help http://www.phildorsett.com/clearancelights.html
Old Jan 1, 2007 | 10:37 AM
Luvnacumns's Avatar
Does anyone know if the holes are on an 06?? It was getting late last night so I forgot tolook...
Old Jan 1, 2007 | 10:38 AM
t-boe's Avatar
Decent write-up, wrong generation of truck. Also you don't have to take the headliner all the down and the wiring is in the passenger side pillar. Good info though. I think when I do mine I'll take pictures as I install them and try to do a good write-up to help future installers.
