Bracket needed for throttle cable on trans
Old Aug 20, 2009 | 09:25 PM
wanago's Avatar
Anyone know where I can get a bracket for the trans that hooks up to the throttle cable. I need to adjust it more so I can fine tune the shifting issues. I already bent the hell out of it. It is working ok but just want to fine tune it better. Any of you have a problem when on on the throttle about 1/3 at low speeds it down shifts really hard and has a hard time up shifting unless you get off the throttle. Really sucks when you see a ricer acting up next to you and this Edit happens. Thanks in advance.
Old Aug 21, 2009 | 03:15 AM
mpracehemi's Avatar
I just made one up when I switched to a floor shifter. Had to fine tune my cable and the stock one wasn't even close. Be careful though, if not aligned properly, you can hurt the trans.. gotta make sure the bottom shift lever is in each gear along with the cable.
bwest1107
Mar 14, 2012 08:42 PM
gottahavediesel
Sep 12, 2010 01:02 AM
90firstgen
Apr 13, 2008 05:48 AM
Kirk T
Sep 20, 2006 07:19 AM
hellotbone
Oct 7, 2003 06:54 AM
