Box stacking
Old Oct 28, 2004 | 03:57 PM
SLEDHEAD's Avatar
Box stacking
I have an edge EZ sitting in my garage, that I had on before the TST came out, and I have an urge to try stacking it with my TST. Right now if I run my PMCR any higher than 5/4, the duration is too long and it actually loses power. I am thinking that by adding the edge, I would get more fuel (via pressure) with the TST still on 5/4. My question is will I see any power increase by doing this, or is more fuel, just more fuel, and I would end up having to lower the TST settings?
Does this make sense? Did I explain that correctly?
See Sig for current mods
Old Oct 28, 2004 | 09:01 PM
Gypsyman's Avatar
This is an excellent stack! I tried the EZ and now I'm running the VA. With some pressure added in you be able to make more power at lower setting. This will give you cooler temps and a smoother running engine at the same HP levels. Give it a try on the lower setting. You won't be dissapointed!
Richard
Old Oct 28, 2004 | 09:39 PM
blk dually's Avatar
hey guys I am getting my BD downloader tomorrow and will use it to replace my adjustible BD 0-50-90 HP . would these two make a good stack or should I sell the adj. to my buddy and buy ???
The adj. unit works good but seems to miss out at the bottom end and comes on strong mid to top end
Old Oct 29, 2004 | 06:50 PM
hialtitude's Avatar
I stack my downloader with a Bank's and love it. Just be careful on rail pressures.
04ctd
Oct 5, 2006 08:27 PM
JDGnut
Jul 18, 2005 08:57 PM
Boss Hoss 540
Apr 26, 2005 12:21 PM
doug
May 7, 2004 04:18 PM
Timinva
Nov 23, 2002 05:44 PM
