boost gauge install on 04.5
i have been searching for like an hour now and can not find a good link to some instructions on where to hook up the boost gauge to the motor and if I need any adapters. Anyone know of a link I can look at, my gauge is and iispro and came with the tubing, i just may need a tee or something. thanks.
I got a manifold boost bolt when I bought my gauge....all you do is unscrew one of your intake bolts and screw in the new boost bolt...then plug in the hose...pretty easy install. PM me if you need to know where I got it from. (not sure if mentioning names is authorized here)
Gauge install
At the bottom of our gauge page http://www.dieselpowerproducts.com/gauges you will find pdf files for installing the gauges, including the boost.
does anyone know if the boost bolt is the same thing as what comes with just a gauge, i got an isspro one, the directions dont say what size it is... from other posts it looks like your supposed to drill and tap it, i can do it but it would look nicer if i dont have to drill and tap it, i like a clean engine compartment, not wires and what not all over the place
go here www.genosgarage.com/ , call them or look for the boost bolt for your truck. Like I said above it is very simple to do this, you just replace your current manifold bolt with the new boost bolt, route the new lines to the cab , tighten all the fittings. Finish up by finding a power source for the gauge lights then put everything back together.
Use the boost bolt man, but don't over tighten it or it will snap off. The torque on a manifold bolt is 18 ftlbs. but anything over 10 will snap that bolt. But it does work pretty darn slick.....
Tank_66
Feb 28, 2008 08:34 PM
