Boost Check on Juice with Attitude!
Old Nov 26, 2005 | 03:13 AM
Big Bob's Avatar
Today I installed a temperory 60# DiPricol boost gauge to compare it against the Attitude. Here are my results.
Under low boost contunious speed, Attitude read 4 to 5#'s, DiPricol read about 2 to 3#'s.
At 65 mph, Attitude read about 9#'s, DiPricol read about 6 to 7#'s.
WOT at 100+ boost levels were very comparible, max boost was between 39 & 40#s on both gauges.
The Attitude seems to respond slower than the DiPricol Mechanical gauge.
With these results, I will not be installing a permanent boost gauge, the Attitude is close enough for me.
Now to check the EGT's.
Old Nov 26, 2005 | 10:41 AM
JCLeary's Avatar
Not surprising. The mechanical gauges are most accurate in the middle of their range.
Old Oct 9, 2006 | 02:47 AM
pet05's Avatar
BIG BOB -
It's been some time but your test showed the MECHANICAL gauge to read close to the electrical Edge Attitude display.
Did you ever get the data back on the EGT #s from a mechanical gauge to the Edge Attitude #s?
Old Oct 9, 2006 | 07:15 AM
one tonne's Avatar
with mine the egt's are really close it just takes more time for the mechanical gauge to respond
Old Oct 9, 2006 | 08:14 AM
RamWheelsBy4's Avatar
That must mean your wastegated at 40psi I would assume. My previous Juice/Attitude and my current TST read pretty close to my Autometer 60psi gauge until about 40psi, that is as high as they read. My II SPS66 is wastegated at 55psi and I see that every run at the track. It is stated in the manual for TST and I believe Juice/Attitude that the boost reading will not read above 40psi.
Old Oct 9, 2006 | 12:23 PM
morkable's Avatar
that is true, the attitude will not read over 39 psi
Kevin
Old Oct 9, 2006 | 04:05 PM
bighornram's Avatar
Mine reads 42 easy - must be an '06 change
Old Oct 9, 2006 | 09:20 PM
morkable's Avatar
on your attitude monitor? It is a well known problem on the attitude, nothing over 39. Unless you have a freak monitor,, lol
Kevin
Old Oct 9, 2006 | 09:24 PM
goose2's Avatar
Mite not be the same on the 06 version.
Old Oct 11, 2006 | 11:07 AM
Big Bob's Avatar
Originally Posted by pet05
BIG BOB -
No, never did, in fact I've sold the Juice and have gone another direction.
Old Oct 11, 2006 | 12:39 PM
When I had the Juice/Attitude & Hot Juice/Attitude both Edge and Autometer pyro sensors were in the top of manifold pre-turbo about an inch apart.
The reading were within +-25*. The digital display is a little slower to respond to change, sub second probably, than the analog gauge. This is the same as my TST EGT pyro sensor that replaced the HOT Juice/Attitude sensor.
5.0 Mustang Man
Oct 21, 2008 02:50 PM
goose2w1
17
Jun 8, 2007 09:04 AM
srt20
Mar 21, 2007 04:49 PM
T & T
Mar 2, 2007 12:27 PM
Lark
Feb 24, 2007 11:02 PM
