Boost
Old Sep 6, 2006 | 01:42 PM
redneck4x4's Avatar
Exclamation Boost
Does anyone know what the stock boost pressure is on an 06 Dodge ??i bought a guage pillar with my guages and for some reason when i get about half throttle my boost guage is already at 30lbs. this doesn't sound right. Let me know what the problem might be so i can fix it. i do have my silencer ring gone and my exhaust open, if this helps any.
Old Sep 6, 2006 | 02:30 PM
RamWheelsBy4's Avatar
Well my 04.5 325/600 would spike to 33-34psi and sustain close to 30psi boost completely stock. That is the numbers that most 04.5-05 have reported. I don't think the 06s would be much if any different. Stock they do spool very fast, especially with improved air flow like you have.
Old Sep 6, 2006 | 06:44 PM
Hairtrigger's Avatar
I can hit no problem with my 2005. besides exhaust the only mod is an edge Juice w/attitude.
I have never put it on levels 4 0r 5!
Old Sep 6, 2006 | 06:47 PM
UnrulyNFS's Avatar
My would run stock at 30 lbs all day which it is meant too. Of course, I saw 33lb spikes every now and then.
Old Sep 6, 2006 | 06:53 PM
973604x4's Avatar
its perfectly normal, if its a problem, we can give you alternatives to fix it. i spike to 48psi
Old Sep 6, 2006 | 07:23 PM
redneck4x4's Avatar
i was just making sure. i had only hit around 18-20 in my Ford so i wasn';t use to those kinds of numbers, plus i didn't know if something was wrong with my guage. i guess it looks like i need the 0-60lb guage. plus when i push the throttle half way i get up to 30 which didn't make since but i guess Dodge's just run higher boost numbers.
Old Sep 6, 2006 | 07:34 PM
bigwheels94's Avatar
If your showing 30 psi boost @ 1/2 throttle,I'd say your gauge is off.Mine will only push about 20 psi,@ 1/2 throttle.But it will hit 32+/- as a spike A WOT,& then drop down to 28-29 psi.What does it say @ WOT?
Old Sep 6, 2006 | 09:59 PM
mickey5978's Avatar
the 06 is not uncommon to see 38-41 psi boost at wot. A different design for the 06 motors. Seach the net for specs and you will find them.
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
