Blocking The Wastegate
Old Nov 5, 2006 | 11:01 PM
Duallydog's Avatar
As safe as anything that is built in on modules.
Old Nov 6, 2006 | 07:36 AM
MikeyB's Avatar
Originally Posted by Duallydog
I'm not finding one on Ebay
Here's one...
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
MikeyB
Old Nov 6, 2006 | 09:13 AM
Duallydog's Avatar
Thanks, I couldn't find anything like that last night.
Old Nov 6, 2006 | 10:57 AM
BossHogg's Avatar
yes
Originally Posted by MikeyB
Is that with the stock turbo??!!!
MikeyB
Yes this is on a stock turbo, I see 43psi when all is cranked up, but I see 35psi or greater a lot!
Old Nov 6, 2006 | 11:02 AM
BossHogg's Avatar
I say dont waste your time going with the adj boost elbow, I did that and feel the benefit outweighs the risk!
Old Nov 6, 2006 | 11:04 AM
BossHogg's Avatar
No kaboom yet and over 20k hitting that spike pretty often, and seeing close to that almost every day. Id say I hit 40psi on a daily basis when I punch it! Which is on a daily basis! yes its the 305/554 your talking about!
Old Nov 6, 2006 | 11:09 AM
BossHogg's Avatar
And i hope it goes Kaboom, which I doubt it will if it hasnt made any sign of it yet!
I could use an excuse to get a bigger turbo!
Old Nov 6, 2006 | 11:43 AM
Duallydog's Avatar
Yeah I don't need to go that high. At least with this turbo.
Old Nov 6, 2006 | 01:16 PM
35" 05''s Avatar
i hear ur safe as long as u dont go over 40psi on stock.. thats why i need a new turbo!
Old Nov 6, 2006 | 01:22 PM
subspd's Avatar
So 40psi is the limit?
Old Nov 6, 2006 | 01:24 PM
subspd's Avatar
I see that the boost elbow posted will not work with an 06' is this true of all of them?
35" 05''s Avatar
yeah I wouldnt go much over that. I hit 40 pretty easy with larry and xzt any more and ill need a new turbo
Old Nov 6, 2006 | 07:52 PM
emfc_22's Avatar
i have no idea how you can hit 40 psi everyday with the 555 versoin turbo. i hit 42 maybe three times in about two days and on the third day it was toasted! (but as you said before though it does give you a great reason to upgrade, and the old lady won't get as mad )
Old Nov 6, 2006 | 11:33 PM
B.Law's Avatar
I had the boost elbow that came with the EZ in for awhile, and with the EZ on 40hp setting and the Van Aaken C3.2 set on the 130hp setting I could hit a little over 45psi on the stocker. Pulling hills, EZ on 70hp, C3.2 on 70hp (where I usually keep it at) I could hold boost at 40psi very easily. I can say this though, boost pressures over 40 made the turbo sound weird, almost inaudible, I doubt she could take much more. I didn't play like this very long till i put the stock boost elbow back in. Even with the stock elbow I can hit a tich over 35psi, and hold 30psi fairly easily.
Old Nov 6, 2006 | 11:40 PM
RAT_03's Avatar
DTR's "Secret Agent"
i been hitting 46psi all the time on stock turbo, running good so far! lol
