BD twins on 06- what psi before head studs
Winner winner chicken dinner!
I have an 06 CTD with BD twins and Intercooler, I have arp head studs but am having a hard time getting them installed. Have heard from web sites, ads,and friends 50psi is safe for the new CTD with no studs. I am running it low at 42psi untill I get studs, but can I get away with a little more? Last thing I need is a blown head gaskett. (plan to run52-65psi after studs)
Also anyone have any idea what a good labor price is for install? The 2 shops I talked to want to charge me an hourly rate but cant really tell me how long it will take. Anyone know of a good shop in the Northern Virginia area? Thanks alot.
I don't have an answer for this, but I noticed you don't have your signature filled out. Most of us fill it out with what kind of truck we have along with mods. That way, people know exactly how to help and give advice. Just a thought.
Ive put studs in a gasser, just chased the threads before putting them in, is it the same concept for the cummins, or should a "professional" do it?
Basically what Im saying is, can I do this in my driveway?
Originally Posted by wap
06dmc, did you do the, start in the middle and work your way out with the head still on method?
Any tips?
Any tips?
Yep, sure did, and it went pretty smooth. Pulled first bolt, cleaned down all the way to the bottom using a hanger with a hook at end so I could attach a strip of a shop rag and just kept using a clean strip til she came out clean.
There is a lot of cutting oil down in the bottoms of some and dry as a bone in others.
I didn't use a bottoming tap as it wasn't needed, I did use arp lube but followed torque specs giv'n to me by II.
When you go to put the rocker cover back on you have to notch it as the front and back studs just barely hit it----once you see where they hit its no big deal----sounds scarier than it is.
All in all pretty easy and the piece of mind it gives you is a great feeling!!
1 more thing, right or wrong, I was told to let the engine warm up fully then pull it right back in and pull'm down hot (retorque)
Let me know if you have any other questions.
smokewagon
Aug 8, 2008 09:54 PM
MikeThomas
May 11, 2008 11:39 AM
jmccart
21
May 14, 2007 11:47 AM
