BD Diesel Ram X PWR Plus 03-04
Old Jan 17, 2006 | 10:13 AM
tcr's Avatar
tcr
Has anyone tried this box? I'm looking for something that will add duration to my Banks setup. The mfg says it will work, although it is both timing and duration. Any info appreciated, Thanks!
Old Jan 17, 2006 | 01:21 PM
Gypsyman's Avatar
Read thru the description. Unless something has changed in the last day or 2 it doesn't do timing on the '03/'04 trucks. Considering the failure rate of these modules I would go with the VA C3.2 long before the BD version.
Old Jan 17, 2006 | 02:23 PM
tcr's Avatar
tcr
From what I here the VA 3.2 won't work w/ the banks, are they the same type of box(Van Aaken and BD)?
Old Jan 17, 2006 | 02:27 PM
hognutz's Avatar
i guess it would depend on how much timing each one adds.
now I have read that the VA 3.2 did not work in thread on hear. I can't remeber what the difference between the va 3.1 and 3.2 are.
I would think you would want duration only but I suppose a duration and timing might be okay if the timing was fairly mild on each box.
Old Jan 17, 2006 | 07:19 PM
B.Law's Avatar
They don't make the Plus for the 03-04 Cummins yet, only 04.5+. I emailed BD just over 2 weeks ago and ask them if they had one in the works and they said possibly, but it is on the back burner at the moment. They said they are too busy getting stuff out for the 06 Cummins.
mitchellalso
Jan 11, 2011 08:26 AM
35" 05'
Nov 5, 2007 09:30 AM
Remmy
May 8, 2006 08:32 PM
DmaxEter
Mar 9, 2006 07:38 PM
