BD boost builder
you can mess with the wastegate all you want. comes down to the ability to fuel and produce enough boost to reach the new wastegate settings.
if you are wanting more boost than here
http://www.dieselperformance.com/ind...oduct/index/7P
If you are talking about a boost fooler than here
http://www.dieselperformance.com/ind...oduct/index/8P
The boost fooler will do nothing for you except keep the check engine light off when you are pushing more than 45ish psi. tricks the ECM into thinking it is lower than it actually is. With your manually wastegated turbo plus the edge, you are not pushing enough fuel to utilize one. waste of money and no power gains.
blong219
Jan 23, 2008 11:47 AM
JD311
Jan 12, 2008 07:31 PM
grecododge
Nov 17, 2007 11:03 PM
