Banks Techni
Old Mar 17, 2006 | 06:19 PM
Duallydog's Avatar
Banks Techni
Any one running the Banks Techni-cooler? Does it help as much as the adds say?
Old Mar 17, 2006 | 10:20 PM
twest's Avatar
On stock Turbo Lag will increase, it Does Drop cruising temps,My IAT gage when cruising over 30 MPH is within 1 to 3 degrees of ambient Temp,The real feeling is when you upgrade your Intake and Turbo along with exhaust,You can contact us here www.tcdieselperformance.com
Old Mar 17, 2006 | 11:11 PM
tristan21's Avatar
yup what twest said xcept I will say it keeps your egt's lower as far as ive seen
Old Mar 18, 2006 | 07:18 PM
metal_miner's Avatar
Why would this happen? It would seem with less pressure drop through the intercooler in conjunction with the fast spool of a stock turbo that the truck would fuel faster due to the MAP sensor seeing more boost earlier.
The stock IC sucks! I hooked up a scanner and when my wastegate opened (bench set at 40 psi) under a hard WOT run, the boost gauge was only at 30-35 psi! Needless to say, I have a Techni-cooler showing up Monday...
Old Mar 18, 2006 | 07:51 PM
PourinDiesel's Avatar
more area to pressurize.
Old Mar 18, 2006 | 10:16 PM
twest's Avatar
Originally Posted by JStieger
Why would this happen? It would seem with less pressure drop through the intercooler in conjunction with the fast spool of a stock turbo that the truck would fuel faster due to the MAP sensor seeing more boost earlier.e was only at 30-35 psi! Needless to say, I have a Techni-cooler showing up Monday...
Banks Techni-cooler has No inside Turbolators ,add the side plus no Turbolators makes for allot more to pressurize.
PourinDiesel
21
Apr 30, 2007 09:55 PM
06er
Oct 8, 2006 10:01 AM
schorb
Mar 13, 2006 08:14 AM
Lrdchaos
Feb 9, 2006 06:36 PM
bradmulvey
14
Jan 27, 2006 12:18 AM
