Baffle section
Old Nov 17, 2005 | 05:32 PM
slimpicken's Avatar
Baffle section
What size pipe do i need to get to make a hommade torqe tube. I have measured the baffle section and it measured roughly 5-1/4" od. SO do I go 5" or 5.5" tubing since they don't seem to make a 5-1/4" pipe?
Old Nov 17, 2005 | 05:35 PM
MikeyB's Avatar
I used a piece of 5.5" aluminum tubing from airflow online. Works great.
MikeyB
Old Nov 17, 2005 | 05:58 PM
HorseHauler's Avatar
yup, 5.5" tubing from airflow online as well
Old Nov 17, 2005 | 06:47 PM
Hunter11's Avatar
Mine looks just like HorseHaulers and I got it from the same place.
Old Nov 17, 2005 | 08:38 PM
slimpicken's Avatar
10-4 thanks guys I'll be ordering that tonight.
Old Nov 17, 2005 | 11:11 PM
Buffalo's Avatar
Airflowonline.com
I must be doing something wrong but, I can't get anything form that website. Is that the correct one? How much does that 5.5" tube cost?
Thanks.
Joe F.(Buffalo)
Old Nov 17, 2005 | 11:19 PM
strokethis600's Avatar
What i did was pry the top off the baffle, then pulled the baffle out, then reglued the baffle back together. didnt cost a thing.
Old Nov 17, 2005 | 11:22 PM
big red psd cc's Avatar
I used a coffee can (litterally).....a coffee can.
I think it was a 1 pound ca, tore off the label, put the coffee in a zip-loc for later use ....and painted it black.
$4.99....plus coffee to boot
Old Nov 18, 2005 | 12:03 AM
whatdieseltoget's Avatar
I did the same thing. I used the stock tube and removed the baffling. I made it way harder than it needed to be though. One of the ends will come off if you pry it hard. Then just glue it back together. Free.
Old Nov 18, 2005 | 12:34 AM
napa 600's Avatar
ditto........
Old Nov 18, 2005 | 08:14 AM
slimpicken's Avatar
very good idea will it just slide out then? I would do it this morning but its still 27* outside my house. Last week it was 90* for most of the week I HATE COLD WEATHER . Anyway thanks for the simple idea I was afriad I'd have to totaly break it to get tos things out.
Old Nov 18, 2005 | 08:23 AM
MikeyB's Avatar
Thanks.
Joe F.(Buffalo)
Here's the site.
http://store.airflo.com/al5-5.html
MikeyB
Old Nov 18, 2005 | 10:21 AM
ed paul's Avatar
[IMG]106_0692[/IMG] this is what i did,,slipped some metal betweeen the cross baffles i wanted to keep the cross baffles to straighten out the air flow
Old Nov 18, 2005 | 10:41 AM
ed paul's Avatar
hmmmm,, as soon as i figure out how to get a pic in here i will
Old Nov 21, 2005 | 04:40 AM
N.Johnson's Avatar
I finally got around to doing the baffle removal and silencer ring delete. The cross baffles on mine where held in place by a two piece split plastic pipe. Pryed of the top of the baffle section breaking the factory glued joint ( wasn,t easy) pulled the assembly out and tried to reglue with Krazy glue. That didn't work (amazing) so figured a two part expoxy will surely do it. NOT! The stock tube is made of a plastic that I found the only product would work is "Loctite for all Plastics". Anyway my tube is kind of a mess and I don't trust it longterm but can hear the turbo sing. Not as loud as I hoped. Going to look for a piece of metal pipe, prefer stainless, for a permanent solution. Never did get around to swiss cheesing the airbox.
