autometer guage light problems
Old Apr 28, 2008 | 09:13 AM
Bigsmoke3500's Avatar
i recently just put LED lights in my guages and i noticed that the lights arent the same brightness, i noticed it before in other guages ive put other trucks. what could be causing this to happen? it was even like that with regualar bulbs and i didnt think anything of it, but now its bothering me because there brighter.
thanks
matt
Old Apr 28, 2008 | 10:03 AM
06CTDforAU's Avatar
In the Autometer gauges, I have noticed that the electric gauges and the mechanical gauges have different brightness levels. The electrics are always a lot brighter than the mechanicals. I've got a set of Cobalts in my truck; the boost gauge being the only mechanical gauge. I swapped it for an electric one because the different brightness levels drove me insane. Only problem with going all electric is that it gets pricey.
Old Apr 28, 2008 | 11:38 AM
kaptain101's Avatar
When I installed Autometer gauges with led lighting I found the gauges to bright for my liking, even tho they were hooked up to the dimmer switch. Autometer has a dimmer switch for led bulbs, it works excellent.
Old Apr 28, 2008 | 11:48 AM
XLR8R's Avatar
AutoMeter uses 2 different lighting schemes - for example the UltraLite & UltraLite II series - using incandescent or LED illumination. Of course, the filaments aren't nearly as bright; on longer circuit runs, the difference is pronounced.
In order to help equalize the output in lumens, we retrofit a brighter halogen bulb into the incandescent socket, or wire an appropriately-sized resistor in series with the LED circuit... you could even use potentiometers for the ultimate in ****-retentive synlumescent gauge lighting!
bigragu
May 24, 2006 07:25 PM
PimpRohr
Feb 28, 2006 07:03 PM
trik396
15
Feb 3, 2006 11:08 AM
hunterrj
Aug 4, 2005 09:27 PM
Mike67RS
17
Sep 4, 2004 09:23 PM
